Eleumas31 18 Posted April 12, 2021 Posted April 12, 2021 (edited) Ciao vorrei sapere come modificare il nome presente sul forum. E' collegato a qualche altro servizio, tipo Emby Connect? Grazie. Edited April 12, 2021 by Samuele Santoni
Carlo 4561 Posted April 12, 2021 Posted April 12, 2021 14 hours ago, Samuele Santoni said: Hello I would like to know how to change the name on the forum. Is it connected to any other service, like Emby Connect? Thank you. You should see your login name top right corner in the browser. Click on your name then choose Account Settings from the menu. You should now see your Display Name with a link to change it. If you input the account name in Emby Connect you will need to change it but if you had added your email address you shouldn't have to do anything for Emby Connect. Let us know if you need additional help.
