CJTripper 17 Posted April 11, 2021 Posted April 11, 2021 (edited) I was recently playing around with the ScripterX plugin and realized BASH wasn't installed on my Asustor 5304, it uses SH as it's default shell interpreter. Here are the steps I followed to install BASH and get it working with ScripterX /bin/bash selected as the in ScripterX interpreter: 1. Install Entware 1.0 from Asustor App Central 2. From SSH console session to the NAS: opkg update && opkg upgrade opkg install bash 3.cd /opt/bin sudo cp ./bash /bin/ Note that after a reboot of the NAS, you will have to repeat step 3 to recopy the bash file to the /bin folder ------------------ Update: Replace step 3 for a persistent solution (recreates symlink on startup): sudo echo /bin/ln -s /opt/bin/bash /bin/bash > /usr/local/etc/init.d/S76bash.sh Tested on an Asustor AS5304T, ADM ver 3.5.5.RFC3 Edited April 13, 2021 by CJTripper updated with persistent solution 1 1
Jägs 86 Posted April 13, 2021 Posted April 13, 2021 Brilliant! I've been missing bash on my ASUSTOR... not anymore! Regarding step 3, I think if you copy it to "/usr/local/bin" instead of /bin—or create a symlink there—it should maintain its persistence after reboot. That's my theory, anyway. I'll give it a try and report back during my next reboot.
CJTripper 17 Posted April 13, 2021 Author Posted April 13, 2021 Well, copying bash to "/usr/local/bin" kept the bash file there after reboot. Works great from SSH command line from any directory as "/usr/local/bin" is in the default environmental variable path. However it doesn't work for ScripterX - it seems to be hardcoded to the "/bin/bash" path and doesn't work with just having bash available via the environment path. So I cheated a bit and put a script in /usr/local/etc/init.d/ to create a symlink in /bin for bash. That init.d folder is where the Asustor App Central programs/services start from. Here is the syntax I used to create the simple script file from a SSH console: sudo echo /bin/ln -s /opt/bin/bash /bin/bash > /usr/local/etc/init.d/S76bash.sh It isn't pretty, but I have confirmed it is persistent and Scripter-X can now find it (via symlink) and is happy again. If you need it to load quicker on startup, decrease S76 to a lower number to increase priority. The S has to stay as the Asustor boot script calls all S* files in that init.d directory. Let me know if you come up with something better or more appropriate, I'm not a Linux guy and am just fumbling my way through. Thanks for the symlink suggestion, and motivating me to find a persistent solution.
Jägs 86 Posted April 14, 2021 Posted April 14, 2021 On 4/13/2021 at 1:45 AM, CJTripper said: So I cheated a bit and put a script in /usr/local/etc/init.d/ to create a symlink in /bin for bash. That init.d folder is where the Asustor App Central programs/services start from. Here is the syntax I used to create the simple script file from a SSH console: sudo echo /bin/ln -s /opt/bin/bash /bin/bash > /usr/local/etc/init.d/S76bash.sh Yeah, that was going to be my next suggestion, so you were a step ahead of me! Glad you got it to work.
