bledad 6 Posted April 8, 2021 Posted April 8, 2021 bonjour , voici plusieurs fois que je mets en enregistrement un programme de 2h sur mon iptv je démarre 4mn avant et mis 40 mn apres resultat je n'ai que 32mn d'enregistrement ???
Luke 42240 Posted April 8, 2021 Posted April 8, 2021 Hi there, let's look at an example. Please attach the information requested in how to report a problem. Thanks !
Luke 42240 Posted April 11, 2021 Posted April 11, 2021 Hi there, I've removed your vpn link. Can you please attach the complete log file? Thanks.
bledad 6 Posted April 13, 2021 Author Posted April 13, 2021 ok , i not understand in log recording "for 173.99988345333333 minutes" but recording 30minutes embyserver-63753872400.txt
Luke 42240 Posted April 14, 2021 Posted April 14, 2021 Can you try refreshing the metadata using the 3-dot menu and see if that updates the runtime? Also can you update to Emby Server 4.5.4?
bledad 6 Posted April 14, 2021 Author Posted April 14, 2021 5 hours ago, Luke said: Can you try refreshing the metadata using the 3-dot menu and see if that updates the runtime? please , where ??
Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 Did you try the button with the 3 dots as shown in the picture you uploaded?
bledad 6 Posted May 6, 2021 Author Posted May 6, 2021 ok ,is good , but i have to restart emby server , it's a problem i have to put a crontab for automatique restart the night !!!!
Luke 42240 Posted May 8, 2021 Posted May 8, 2021 On 5/6/2021 at 2:46 AM, bledad said: ok ,is good , but i have to restart emby server , it's a problem i have to put a crontab for automatique restart the night !!!! Why do you think you have to restart emby server?
bledad 6 Posted May 8, 2021 Author Posted May 8, 2021 if i restart server the record is normal for a few days , otherwise it only records 30 or 39 minutes this is what i noticed why , i don't know !!!!
Luke 42240 Posted May 16, 2021 Posted May 16, 2021 Hi there @bledad are you still having an issue with this?
bledad 6 Posted May 22, 2021 Author Posted May 22, 2021 for the moment i cannot , i have iptv change and i cannot record because not epg. for when the programming except epg ?? it's unfortunate to install tvheadend to record , no !!!
Luke 42240 Posted May 22, 2021 Posted May 22, 2021 We plan to support recording without an epg in an upcoming update, so stay tuned.
