artv_saloon 0 Posted April 8, 2021 Posted April 8, 2021 Ho caricato delle liste m3u per vedere in streaming canali stranieri, principalmente russi e spagnoli. Per molti di questi canali la visione è limpida senonchè dopo qualche minuto si blocca e per riavviarla devo tornare al menu canali e riselezionare. In altri casi, invece, dopo circa 30 secondi, lo streaming va in loop continuando a mostrare i 30 secondi iniziali. Chi può aiutarmi? Grazie
Luke 42239 Posted April 8, 2021 Posted April 8, 2021 Hi there, let's look at an example. Please attach the information requested in how to report a problem. Thanks !
artv_saloon 0 Posted April 9, 2021 Author Posted April 9, 2021 Here attached today logs. thx ffmpeg-directstream-644c5c10-b7d8-4b1f-a885-689eeaee990d_1.txt ffmpeg-transcode-4e2af22b-953d-4ba0-8a41-55950910eee0_1.txt
Luke 42239 Posted April 12, 2021 Posted April 12, 2021 Hi there @artv_saloon, please attach the emby server log file as well. thanks.
artv_saloon 0 Posted April 13, 2021 Author Posted April 13, 2021 done.thx embyserver (2).txt embyserver.txt
Carlo 4561 Posted May 23, 2021 Posted May 23, 2021 Could you try 4.6 and let us know if you still have this issue?
Luke 42239 Posted May 23, 2021 Posted May 23, 2021 Hi, yes please try the new Emby Serer 4.6 release and let us know how that compares. Thanks !
artv_saloon 0 Posted June 6, 2021 Author Posted June 6, 2021 NO, same problem. Is there anyone using this plug-in without my problems?
Luke 42239 Posted June 6, 2021 Posted June 6, 2021 4 hours ago, artv_saloon said: NO, same problem. Is there anyone using this plug-in without my problems? Hi, what plugin are you referring to? Can you please provide an emby server log from 4.6?
TJSNHS04 9 Posted September 26, 2021 Posted September 26, 2021 (edited) Stesso problema emby 4.6.4.0,live tv tuner m3u e iptv plug-in,stesso file m3u funziona correttamente su molteplici player Stesso problema emby 4.6.4.0, sintonizzatore tv live m3u e plug-in iptv, lo stesso file m3u funziona bene su più lettori ho formattatto e reinstallato windows e reinstallato emby perchè pensavo ad un problema di os,problema non risolto formatted and reinstalled windows and reinstalled emby because i was thinking about an os problem, problem not solved Edited September 26, 2021 by TJSNHS04
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 You do not use the IPTV plugin for TV channels. You set the M3U files up as a TV tuner in the Live TV/DVR section. Have you done this?
TJSNHS04 9 Posted September 26, 2021 Posted September 26, 2021 20 minutes ago, cayars said: You do not use the IPTV plugin for TV channels. You set the M3U files up as a TV tuner in the Live TV/DVR section. Have you done this? yes yes both view message pvt
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 OK I see from the pic you sent me you have this setup in Live TV. If you look at the m3u file itself what kind of extension is on those streams? If possible could you send me a PM with the m3u link you use so I could take a look at it?
TJSNHS04 9 Posted September 26, 2021 Posted September 26, 2021 8 minutes ago, cayars said: OK I see from the pic you sent me you have this setup in Live TV. If you look at the m3u file itself what kind of extension is on those streams? If possible could you send me a PM with the m3u link you use so I could take a look at it? I use an m3u file flows hls or ts tipo = m3u_plus e output = ts m3u link no
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 TS is preferred as HLS can cause issues with some providers. Typically channels stopping is a provider issue of some kind. I'm not sure how to proceed without being able to actually test the streams. If you like as already mentioned send me the m3u link and we can test them.
TJSNHS04 9 Posted September 26, 2021 Posted September 26, 2021 9 minutes ago, cayars said: TS is preferred as HLS can cause issues with some providers. Typically channels stopping is a provider issue of some kind. I'm not sure how to proceed without being able to actually test the streams. If you like as already mentioned send me the m3u link and we can test them. only emby, other programs same pc same link i m3u work perfectly, privately i sent you a video ...
Carlo 4561 Posted September 26, 2021 Posted September 26, 2021 We would need to have the m3u in order to test and see what the issue might be.
Luke 42239 Posted September 27, 2021 Posted September 27, 2021 @TJSNHS04 can we please look at an example? Please attach the information requested in how to report a media playback issue. You can also send log files via private message. thanks !
TJSNHS04 9 Posted September 28, 2021 Posted September 28, 2021 14 hours ago, Luke said: @TJSNHS04 can we please look at an example? Please attach the information requested in how to report a media playback issue. You can also send log files via private message. thanks ! After several tests, and user agent changes now it seems to work, as per the set photos, if I change it they don't work. the log gave access denied 403, mha only on emby other prog etc it worked Dopo vari test,e cambi user agent adesso sembra funzionare, come da foto impostati,se cambio non funzianano. il Log dava accesso negato 403,mha solo su emby altri prog etc funzionava 2
Super957 24 Posted May 6, 2022 Posted May 6, 2022 On 9/28/2021 at 9:12 AM, TJSNHS04 said: After several tests, and user agent changes now it seems to work, as per the set photos, if I change it they don't work. the log gave access denied 403, mha only on emby other prog etc it worked Dopo vari test,e cambi user agent adesso sembra funzionare, come da foto impostati,se cambio non funzianano. il Log dava accesso negato 403,mha solo su emby altri prog etc funzionava Posso avere il testo che hai inserito in Referrer http header Grazie Hispa 1 1
