Rikitydj 3 Posted April 7, 2021 Posted April 7, 2021 Hi guys I've noticed now more and more suppliers are moving away from M3U addresses. Is there going to be a way of getting iptv working through emby without having to use an M3U? Thx!
Solution Carlo 4561 Posted April 7, 2021 Solution Posted April 7, 2021 (edited) Hi, No, m3u is the defacto method of stream entry into Emby. If this other method has the stream URLs available and they work by themselves in VLC they should still be usable in an m3u file if hand crafted. Edited April 7, 2021 by cayars
BillOatman 597 Posted April 7, 2021 Posted April 7, 2021 (edited) @cayars I believe he is talking about "xtreme codes" which is a rest call made to get the stream links instead of using a m3u file. @RikitydjEmby doesn't have that capability so you need to use a tool to create a m3u like cayars suggested. IPTVBoss is a good free tool that can use the XC url to get the data and create m3u and associated xmltv files. I don't think xTeVe has that capability. I imagine there are others. Edited April 7, 2021 by BillOatman 1
Carlo 4561 Posted April 7, 2021 Posted April 7, 2021 4 minutes ago, BillOatman said: IPTVBoss is a good free tool that can use the XC url to get the data and create m3u and associated xmltv files. Have a URL for IPTV Boss?
BillOatman 597 Posted April 7, 2021 Posted April 7, 2021 1 minute ago, cayars said: Have a URL for IPTV Boss? Its only available via a discord channel as far as I am aware, I believe I can send you a discord invite if you like. 2
Carlo 4561 Posted April 7, 2021 Posted April 7, 2021 Thanks. I've seen you mention it before but couldn't find much via Google on it.
BillOatman 597 Posted April 7, 2021 Posted April 7, 2021 Just now, cayars said: Thanks. I've seen you mention it before but couldn't find much via Google on it. OK, it wont be until tonight. Work put a blocker on things like discord 1
BillOatman 597 Posted April 7, 2021 Posted April 7, 2021 1 minute ago, ebr said: Please don't post a link out here. Thanks. No worries, I was going to send it to cayars. 1
Carlo 4561 Posted April 7, 2021 Posted April 7, 2021 @ebr If you like delete the last couple messages here and we'll take it to PM.
