moviepalace4K 30 Posted April 6, 2021 Posted April 6, 2021 (edited) Hello, I've been having trouble streaming movies for several days now. These will start, but each movie hangs for a while and then continues (multiple times per movie). This is on the AndroidTV app. What have I already checked ?: 1) Internet connection 2) Server: defragmenter, cleaning files and registry keys etc. AndroidTV app: maximum streaming bitrate set at 160 Mbits / sec. server log is attached I have also sent the AndroidTV logs to the developer Can anyone help? greetings Patrick embyserver.txt Edited April 6, 2021 by Privateyes
Luke 42203 Posted April 6, 2021 Posted April 6, 2021 Hi, try removing the smartthings plugin, then restart the server and see how that compares.
moviepalace4K 30 Posted April 6, 2021 Author Posted April 6, 2021 (edited) @Luke I just removed the Samsung smartthings plugin from the server and rebooted but no improvement. Edited April 6, 2021 by Privateyes
ebr 16309 Posted April 6, 2021 Posted April 6, 2021 4 hours ago, Privateyes said: app: maximum streaming bitrate set at 160 Mbits / sec. Hi. I can see you are streaming remotely. What is the speed of the connection on both ends? Up at the server and down at the client? And what is the bitrate of the content?
moviepalace4K 30 Posted April 7, 2021 Author Posted April 7, 2021 (edited) The up is 50mbit/sec, the down is 300mbit/sec. I uninstaller all the smatthings plugins from the server and I think the problem is solved now. Edited April 7, 2021 by Privateyes
ebr 16309 Posted April 7, 2021 Posted April 7, 2021 Okay. Let us know if it crops back up but 50 up from the server is not necessarily going to allow all your remote apps to direct play - depending on how many at once and the bitrate of the content.
moviepalace4K 30 Posted April 19, 2021 Author Posted April 19, 2021 The bit rate is an average of 7000 kbps per 4k movie (I only have 4k movies on my server (+3400 pieces))
Carlo 4561 Posted April 19, 2021 Posted April 19, 2021 On 4/7/2021 at 6:45 AM, Privateyes said: I uninstaller all the smatthings plugins from the server and I think the problem is solved now. Nice, keep an eye on playback for a few days and keep us informed. Thanks
BillOatman 597 Posted April 19, 2021 Posted April 19, 2021 8 hours ago, Privateyes said: The bit rate is an average of 7000 kbps per 4k movie (I only have 4k movies on my server (+3400 pieces)) Out of curiosity, how many clients can you have streaming those 4K files at once?
moviepalace4K 30 Posted April 19, 2021 Author Posted April 19, 2021 1 hour ago, BillOatman said: Out of curiosity, how many clients can you have streaming those 4K files at once? I can handle 4-5 clients at the same time 1
