onio 0 Posted May 22, 2021 Author Posted May 22, 2021 3 minutes ago, Luke said: You can't import from an excel file. I would suggest checking out our Live TV setup guide here: https://support.emby.media/support/solutions/articles/44001160415-live-tv-setup Thank you your quickly reply, sorry i cannot prepare excel file EPG to xml
onio 0 Posted May 22, 2021 Author Posted May 22, 2021 11 minutes ago, onio said: Thank you your quickly reply, sorry i cannot prepare excel file EPG to xml Do you have a example xml file template? can i change channels program?
onio 0 Posted May 22, 2021 Author Posted May 22, 2021 20 minutes ago, Luke said: http://wiki.xmltv.org/index.php/XMLTVFormat how to load EPG automatically from web site? its possible? http://www.zuragt.mn/
onio 0 Posted May 22, 2021 Author Posted May 22, 2021 1 hour ago, Luke said: I would contact them and ask them for xmltv data. Thank you
Carlo 4561 Posted May 22, 2021 Posted May 22, 2021 Depending on the channels you have, one of these sources may have them already prepared as xml for you. https://support.emby.media/support/solutions/articles/44002149110-other-sources-of-epg-guide-data
onio 0 Posted June 21, 2021 Author Posted June 21, 2021 On 5/22/2021 at 3:44 PM, Luke said: Hi udp stream file not playing on Version 4.7.0.3 beta, please check Thank you embyserver.txt hardware_detection-63759883579.txt
