Mahtan 3 Posted April 4, 2021 Posted April 4, 2021 Bonjour, J'ai donné l'accès à mon serveur sur un mi TV boxet qui ne se trouve pas dans mon domicile. Donc cette personne y accède en externe. Tout fonctionne très bien mais si ce n'est pas utilisé pendant un certain temps quand la personne ré ouvre emby. L'interface lui redemande de se reconnecter au serveur. Opération fastidieuse car je dois refaire avec emby connect etc. A t'il un option pour empêcher emby de déconnecter les clients en externe au bout d'un certain temps d'inactivité ? Merci ! received_470369597433578.webp
Mahtan 3 Posted April 4, 2021 Author Posted April 4, 2021 J'ai un ddns donc ça devrait pas poser de problème ?
ebr 16334 Posted April 4, 2021 Posted April 4, 2021 6 hours ago, Mahtan said: Tedious operation because I have to redo with emby connect etc. HI. Is he selecting the "logout" option or, possibly, deleting the server from the server selection screen? Unless he is doing something like that, you should not have to re-setup connect. If you give him your address directly and he logs in that way, is there a problem? @cayars
Luke 42240 Posted April 5, 2021 Posted April 5, 2021 On 4/4/2021 at 7:45 AM, Mahtan said: I have a ddns so that shouldn't be a problem? Great ! Did you configure the ddns address as your external address in Emby Server network settings?
Mahtan 3 Posted April 6, 2021 Author Posted April 6, 2021 Yes the link is correct and when I click on it it redirects me to emby. 1
Luke 42240 Posted April 6, 2021 Posted April 6, 2021 Great, so are you all set now? Are you still having an issue?
Mahtan 3 Posted April 7, 2021 Author Posted April 7, 2021 12 hours ago, Luke said: Great, so are you all set now? Are you still having an issue? I will wait a while to see if the problem is solved. As a reminder, instead of using emby connect, I gave my DDNS address directly 1
