enfants 0 Posted April 3, 2021 Posted April 3, 2021 Bonjour j'ai un problème j'essaye de me connecter a mon serveur par emby il me demande nom utilisateur plus mot de passe la je n'ai rien il me revoie pour initialiser le mot de passe et je dois retourner en local bref je tourne en rond et aucune solution
Guest Posted April 3, 2021 Posted April 3, 2021 Do you have an account set up on the EMBY server? Did you set one during set up? Are you using Manual or Emby Connect?
Carlo 4561 Posted April 5, 2021 Posted April 5, 2021 Hi, the first thing I would try to do is log in directly to your server from your local LAN using a web browser. Can you do this successfully?
