GrumpyTrucker 3 Posted April 2, 2021 Posted April 2, 2021 I signed up for a monthly Premiere account to try out the features for a short term. If I cancel my monthly Premiere and sign up to a different plan would that affect any premium plugins I've already registered if the Premiere Key changes?
Solution ebr 16346 Posted April 2, 2021 Solution Posted April 2, 2021 11 minutes ago, GrumpyTrucker said: I signed up for a monthly Premiere account to try out the features for a short term. If I cancel my monthly Premiere and sign up to a different plan would that affect any premium plugins I've already registered if the Premiere Key changes? Hi. If your key changed, yes that would mean that we'd need to transfer the plug-ins over. However, changing subscriptions won't change your key as long as you keep the same email address. Does that answer your question? 1
Happy2Play 9814 Posted April 2, 2021 Posted April 2, 2021 9 minutes ago, GrumpyTrucker said: If I cancel my monthly Premiere and sign up to a different plan There is Premiere and no Premiere, payment plan is irrelavent. Your Premiere key should not change unless you change email address, I believe. But if your Premiere key does change yes it will affect Premium plugins. But you should be able to work all this out with Embybilling and the plug devs. 1
GrumpyTrucker 3 Posted April 2, 2021 Author Posted April 2, 2021 29 minutes ago, ebr said: Hi. If your key changed, yes that would mean that we'd need to transfer the plug-ins over. However, changing subscriptions won't change your key as long as you keep the same email address. Does that answer your question? Yeah, that seems to answer it thanks
