MartiSaTo 0 Posted March 31, 2021 Posted March 31, 2021 Hola! Tengo un problema estoy intentando acceder al servidor emby desde unos dispositivos nuevos no registrados en el servidor. Me da el "Error Server: Access token is invalid or expired" utilizando la aplicación Emby de LG, Emby de Android TV y Emby Android (tablet Huawei). He probado un usuario con y sin contraseña. En la tablet he probado desdel navegador chrome y accedo correctamente sin problemas pero si intento acceder con la aplicación emby de android me da el error. Me podrían indicar donde está el problema. Saludos
Luke 42241 Posted April 1, 2021 Posted April 1, 2021 Hi there what version of Emby Server are you running?
Luke 42241 Posted April 1, 2021 Posted April 1, 2021 Please attach the emby server log from when this happened. thanks.
MartiSaTo 0 Posted April 1, 2021 Author Posted April 1, 2021 (edited) This is the log line where it see the problem 2021-04-01 07:51:38.401 Info Server: http/1.1 GET http:// /Users/authenticatebyname?X-Emby-Client=Emby%20for%20Android&X-Emby-Device-Name=HUAWEI%20MediaPad%20T3%2010&X-Emby-Device-Id=cae372d5c19b6dce&X-Emby-Client-Version=3.1.80. Accept=application/json, Accept-Encoding=gzip, deflate, Accept-Language=ca-ES,ca;q=0.9,en-US;q=0.8,en;q=0.7, Host= , User-Agent=Mozilla/5.0 (Linux; Android 7.0; AGS-W09 Build/HUAWEIAGS-W09; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/89.0.4389.105 Safari/537.36, X-Forwarded-Scheme=https, X-Forwarded-Proto=https, X-Forwarded-For= , X-Real-IP= , x-requested-with=com.mb.android, sec-fetch-site=cross-site, sec-fetch-mode=cors, sec-fetch-dest=empty 2021-04-01 07:51:38.402 Error Server: Access token is invalid or expired. Edited April 1, 2021 by MartiSaTo
Luke 42241 Posted April 2, 2021 Posted April 2, 2021 Hi there, can you please attach the complete emby server log? Thanks.
MartiSaTo 0 Posted April 3, 2021 Author Posted April 3, 2021 Hi. complete log with the error access. embyserver.txt
Carlo 4561 Posted April 12, 2021 Posted April 12, 2021 @MartiSaTo Are you still running into this issue?
Luke 42241 Posted April 13, 2021 Posted April 13, 2021 What is the process that you are using to try and sign in?
Solution MartiSaTo 0 Posted April 13, 2021 Author Solution Posted April 13, 2021 Hi, I connect through nginx proxy manager. Today I have tried to disable the Force SSL option. Now I have been able to connect from the three new devices. Thanks for your help
