cnsixeyes 0 Posted March 31, 2021 Posted March 31, 2021 I'm trying to use https for remote connections using Synology reverse proxy and I don't have a certificate Here what I did so far: 1. Setup DDNS on my router 2. Create a reverse proxy setting on port 8921 to redirect to localhost:8096 3. Setup port forwarding on my router to forward port 8921 to my NAS port 8921 4. Setup emby advance settings, I set the secure connection mode to "Handled by reverse proxy". but it didn't work, Did I miss a setting somewhere? Thanks for the help! However, if I use local IP instead: screenshot my settings:
Luke 42243 Posted April 1, 2021 Posted April 1, 2021 Hi, do the requests show up in the emby server log? that will help tell you if it's even making it to emby server, which i would guess not. Perhaps keep it simple and start http only first just to get the reverse proxy sorted out, then add https after that.
Solution cnsixeyes 0 Posted April 1, 2021 Author Solution Posted April 1, 2021 48 minutes ago, Luke said: Hi, do the requests show up in the emby server log? that will help tell you if it's even making it to emby server, which i would guess not. Perhaps keep it simple and start http only first just to get the reverse proxy sorted out, then add https after that. hi,thanks. I checked the logs,there is no sign of the requests. Maybe i should check the router again. -------------- 1.Checked the Attack Defence AGAIN, I found this: All because of my sloppiness…… Permit the port 8921, problem solved! Thanks Luke!
Luke 42243 Posted April 3, 2021 Posted April 3, 2021 On 4/1/2021 at 2:28 AM, cnsixeyes said: hi,thanks. I checked the logs,there is no sign of the requests. Maybe i should check the router again. -------------- 1.Checked the Attack Defence AGAIN, I found this: All because of my sloppiness…… Permit the port 8921, problem solved! Thanks Luke! HI, thanks for the feedback. Glad you were able to resolve it.
