BruceDavid 4 Posted March 29, 2021 Posted March 29, 2021 Hi, I have a number of TV series on Emby and they work perfectly. With one exception. I have a number of DVD rips of the Dick Cavett Show. Those DVDs are not sold nor sorted by season/episode. Rather, it is by topic. I have the following directories under my TV\Dick Cavett Show directory, each of which corresponds to a different DVD: John & Yoko Comic Legends Hollywood Greats Rock Icons Each directory has a number of MP4 files in it (one for each episode). I have Emby set to order by directory rather than series, etc. and am trying to figure out what naming convention to use to get the episodes to display when I click on "Comic Legends" (for example). Emby either puts them into various seasons and/or does not display all of the episodes. Thanks for the help, much appreciated. Best, Bruce
Solution Luke 42203 Posted March 29, 2021 Solution Posted March 29, 2021 Hi there, have you compared your file and folder naming to our TV naming guide? https://support.emby.media/support/solutions/articles/44001159110-tv-naming
BruceDavid 4 Posted March 29, 2021 Author Posted March 29, 2021 Thanks, I hadn't noticed the date format section (as shown below in case anyone else has this issue) before, that solved the problem. anything_1996.11.14.ext anything_1996-11-14.ext anything_14.11.1996.ext
