CharleyVarrick 283 Posted March 28, 2021 Posted March 28, 2021 Short story, I lost all Emby favorites and watched status a month or so ago; please dont ask how, it stills hurt. I do have a Trakt acct, and having nothing to lose, I am wondering how to request Trakt to try to update my emby libraries? Where can I find "Trakt 101 for newbies" ? 1
Luke 42154 Posted March 28, 2021 Posted March 28, 2021 Hi, as this is a community contributed plugin, there isn't a whole lot of documentation, but hopefully it's settings are straight forward enough. Just keep in mind when you sync to trakt, you're sending data from your server to Trakt, and when you sync from Trakt, it's the other way around. So that means data on one side will be replaced with data from the other.
CharleyVarrick 283 Posted March 28, 2021 Author Posted March 28, 2021 1 minute ago, Luke said: Hi, as this is a community contributed plugin, there isn't a whole lot of documentation, but hopefully it's settings are straight forward enough. Just keep in mind when you sync to trakt, you're sending data from your server to Trakt, and when you sync from Trakt, it's the other way around. So that means data on one side will be replaced with data from the other. Hi Luke, I definitely not want to send (no data) from emby to Trakt, but was wishing to be able to send (some) data from Trakt to Emby. In scheduled task I hit play arrow and it ran 0 seconds, that can't be good
CharleyVarrick 283 Posted March 28, 2021 Author Posted March 28, 2021 (edited) Out of curiosity, where are favorites/played status saved ? I was thinking it was within respective .nfo's, but none of my nfo show either lines. Is there a settings or option somewhere in emby? Edited March 28, 2021 by CharleyVarrick
Luke 42154 Posted March 28, 2021 Posted March 28, 2021 Quote Out of curiosity, where are favorites/played status saved ? It's in your emby server database files.
