hemandk 12 Posted March 28, 2021 Posted March 28, 2021 Hi, So I have seem to have an issue with freezing when I direct play and is much better when transcoding. This happens with both live tv and mkv files stored on my server. My server is on a 300/300mbit fiber so I don't think the issue is there. My client in my summerhouse is on a 4G broadband connection but I generally have around 80mbit download. It seems to me that Emby does not buffer/cache enough of the stream or does it not buffer/cache at all when live streaming?
Luke 42203 Posted March 28, 2021 Posted March 28, 2021 Hi, generally it means the bitrate is too high for the connection, and then transcoding lowers the bitrate to allow it to play smoothly. Quote My server is on a 300/300mbit fiber so I don't think the issue is there. My client in my summerhouse is on a 4G broadband connection but I generally have around 80mbit download. There could be ISP throttling occurring on either side of the connection, causing you to end up with much lower speeds than you are expecting.
Guest Posted March 28, 2021 Posted March 28, 2021 I HATE throttling... just a note.. Took me hours to upload to OneDrive.. almost 8 hours on 50/Cable..
hemandk 12 Posted March 28, 2021 Author Posted March 28, 2021 @Luke So a 1000Mbyte tv show is ~ 8000Mbit. It takes 43min*60sec/min = 2580 sec, so that is roughly 8000/2580 ~ 3 Mbit/s to direct play. I might be wrong in that calculation? But obviously being on a 4G LTE connection I will have drop outs etc. So does the Emby client buffer/cache more of the file when direct playing? Or is just streaming without any buffering/catching? You did not really answer that question?
Luke 42203 Posted March 28, 2021 Posted March 28, 2021 Quote So does the Emby client buffer/cache more of the file when direct playing? Or is just streaming without any buffering/catching? The apps all have a small buffer but it's essentially streaming.
hemandk 12 Posted March 28, 2021 Author Posted March 28, 2021 13 minutes ago, Luke said: The apps all have a small buffer but it's essentially streaming. Can this buffer be changed? I'm just trying to avoid transcoding all the time and save some server load.
Luke 42203 Posted March 28, 2021 Posted March 28, 2021 1 hour ago, hemandk said: Can this buffer be changed? I'm just trying to avoid transcoding all the time and save some server load. Hi, not currently, no.
