Ninko 78 Posted May 28, 2021 Author Posted May 28, 2021 I couldn't say for certain, when I'm watching something I don't tend to remember every button I pushed previously, so it's possible. I haven't yet no, I'll let you know when I have. Thanks
Ninko 78 Posted May 28, 2021 Author Posted May 28, 2021 Ok, I'm currently testing the beta version, so far it's working correctly. I'll let you know if that changes. Thanks
Luke 42241 Posted May 29, 2021 Posted May 29, 2021 3 hours ago, Ninko said: Ok, I'm currently testing the beta version, so far it's working correctly. I'll let you know if that changes. Thanks thanks for the feedback.
junkyj753 0 Posted May 29, 2021 Posted May 29, 2021 I have same issue with my EMBY Windows install even though Series sorted by "aired". Don't know what is needed for diagnosis. Happy to provide. TIA
ebr 16334 Posted May 29, 2021 Posted May 29, 2021 1 hour ago, junkyj753 said: I have same issue with my EMBY Windows install even though Series sorted by "aired". Don't know what is needed for diagnosis. Happy to provide. TIA Hi. This can't be the same issue as it is a different device and app and, I think, different issue altogether as this appears to be related to display instead of playback. Please start a new thread in the web app section with an explanation of exactly what issue you are seeing. Thanks.
Ninko 78 Posted May 29, 2021 Author Posted May 29, 2021 Still seems to be working correctly, possibly fixed?...
ebr 16334 Posted May 29, 2021 Posted May 29, 2021 2 hours ago, Ninko said: Still seems to be working correctly, possibly fixed?... Good to hear. Thanks.
junkyj753 0 Posted May 30, 2021 Posted May 30, 2021 Shows played out of order AND displayed out of order. I have since dl'd the Beta version and issue is resolved on that side but not on the stable side. Providing feedback: Not a fan of these forums because of the unapproachability of the administrators.
Luke 42241 Posted May 30, 2021 Posted May 30, 2021 Thanks for the feedback. Glad to hear that it's resolved for you. We'll work to make ourselves more approachable. Thanks.
Ninko 78 Posted June 3, 2021 Author Posted June 3, 2021 This problem appears fixed in the beta version. When will this fix make it's way into the stable version? Thanks
Ninko 78 Posted June 3, 2021 Author Posted June 3, 2021 Ah right, I can stop using the beta version then, thanks.
ebr 16334 Posted June 3, 2021 Posted June 3, 2021 Actually, it is not in stable yet but we will submit fairly soon. Thanks.
