Luke 42241 Posted April 10, 2021 Posted April 10, 2021 26 minutes ago, lowe1739 said: my Roku and Emby just keep crashing. Worked last night no issues but now. no dice. I'm guessing this part of this same type of issue ?? Hi, yes do the details being discussed here apply to you?
lowe1739 3 Posted April 10, 2021 Posted April 10, 2021 yeah I just verified my Roku version is 10.0.0.4165 and it updated last night. I just added the beta Emby to it and will try that in a bit, to see if that works. I can sell to ebr if he still wants it! haha its the Roku ultra. will report soon. 13 minutes ago, Luke said: Hi, yes do the details being discussed here apply to you?
lowe1739 3 Posted April 10, 2021 Posted April 10, 2021 2 minutes ago, lowe1739 said: yeah I just verified my Roku version is 10.0.0.4165 and it updated last night. I just added the beta Emby to it and will try that in a bit, to see if that works. I can sell to ebr if he still wants it! haha its the Roku ultra. will report soon. @Luke yep Beta app worked no issue. Cool i'm good using that the main app is updated.
Dewberry1 0 Posted April 13, 2021 Posted April 13, 2021 Somehow Roku version 10 got on my device. No I'm not a beta tester. My other Roku has version 9. Now because of version 10 emby does not work...how do I get back to version 9. I've tried the home 5 times and it doesn't work
Happy2Play 9811 Posted April 13, 2021 Posted April 13, 2021 (edited) 9 minutes ago, Dewberry1 said: Somehow Roku version 10 got on my device. No I'm not a beta tester. My other Roku has version 9. Now because of version 10 emby does not work...how do I get back to version 9. I've tried the home 5 times and it doesn't work What do you mean it didn't work as dozens have already rolled back firmware. You other option in leave the firmware and use the Emby Roku Beta channel. Edited April 13, 2021 by Happy2Play
ebr 16335 Posted April 13, 2021 Posted April 13, 2021 On 4/13/2021 at 3:33 PM, Dewberry1 said: Somehow Roku version 10 got on my device. No I'm not a beta tester. My other Roku has version 9. Now because of version 10 emby does not work...how do I get back to version 9. I've tried the home 5 times and it doesn't work Hi. Please install the beta of the app and let us know if it works properly. Thanks.
pwhodges 2033 Posted April 13, 2021 Posted April 13, 2021 38 minutes ago, Dewberry1 said: I've tried the home 5 times and it doesn't work But that's only half the incantation! Home*5 then ScanForward*3 then ScanBack*2 is what you want. Or just install the Emby beta which fixes this (then do the incantation to take your Roku off the beta stream, though we've been told this doesn't actually work either!). Paul
dimitrik 14 Posted April 14, 2021 Posted April 14, 2021 Beta app version works and also seems a bit faster. Thanks!
ebr 16335 Posted April 14, 2021 Posted April 14, 2021 1 hour ago, dimitrik said: Beta app version works and also seems a bit faster. Thanks! Thanks for reporting back.
bbdude 0 Posted April 15, 2021 Posted April 15, 2021 Beta app version works for me also. Thanks. So at some point, I assume the Beta or its offspring will be released and then I assume we should resume using the released App. What is the best way to get notified when this happens?
Happy2Play 9811 Posted April 15, 2021 Posted April 15, 2021 1 minute ago, bbdude said: Beta app version works for me also. Thanks. So at some point, I assume the Beta or its offspring will be released and then I assume we should resume using the released App. What is the best way to get notified when this happens? No easy way as updates are transparent to the user. I guess you could follow the release notes or Latest Release topics. Emby for Roku Release Notes - Roku - Emby Community https://emby.media/community/index.php?/topic/21348-emby-latest-versions/&do=findComment&comment=208311 Possibly Announcements/blogs assuming on is published for this update.
ebr 16335 Posted April 16, 2021 Posted April 16, 2021 Hi. Yes, an update is already under review by Roku. It should be live sometime on Monday (hopefully).
ebr 16335 Posted April 19, 2021 Posted April 19, 2021 The new version of the Roku app has been released. If you run into this issue, just force an update of the channel. Thanks. 1
lowe1739 3 Posted April 21, 2021 Posted April 21, 2021 On 4/19/2021 at 1:58 PM, ebr said: The new version of the Roku app has been released. If you run into this issue, just force an update of the channel. Thanks. it works! thanks everyone! Roku 4k Ultra
plittlefield 56 Posted April 21, 2021 Posted April 21, 2021 I have updated to 4.0.26 and all good here.
