External Subtitles and MB Clients
In Media Library wiki  says:
[ All video files can have external srt subtitles. The filename must match the video filename, or be suffixed with a language.
/Movies
   /Home Alone (1990)
      Home Alone.mkv
      Home Alone.srt
      Home Alone.spa.srt
      Home Alone.spanish.srt
Languages can be specified using either the three character ISO code, which is preferred, or the full english name
If the subtitle filename has no ISO code, clients (except the MBClassic) see it as undefined (Android client) or not at all (MediaBrowser Theater).
So is it a bug of clients or should I rename my hundreds of srt files?
All my Media files are shared and Library folders use UNC paths and I am using a Windows MediaBrowser Server
I apologise If there is already reported but I couldn't find any answer.
I have tried 2 more clients so far (apart from MBClassic) and I would like to report the following:
1) MediaBrowser Classic (local network only):
It never had a problem playing these undefined or Lang-suffixed srt subtitles. It works perfect as MB2 which I had been using for years.
2) MediaBrowser Theater:
If installed on the same system with MB Server, it recognises and plays only lang-suffixed srt files.
if installed on different system in local network, It sees only the lang-suffixed srt subtitles but it doesn't play them. That makes it not useable for everybody.
if connected to a MediaBrowser Server on other network, it plays lang-suffixed srt subtitles but only because they are hardcoded in the streaming video it gets from server.
3) Android Client:
It always gets a streaming transcoded ts file so if the srt files are lang-suffixed no problem
but if not, It doesn't play the video at all. It waits forever.
Edited by spyko
