Skyobliwind 7 Posted March 25, 2021 Posted March 25, 2021 I added all Marvel MCU Films in 4k to my libary, but if I use the filter option only Guardians of the Galaxy is still missing there. What is the criteria the 4k Filter option uses? I couldn;t find the difference yet. The information under "mediainformation" at the bottom looks quite similar. Is found using the Filter: Title 4K HEVC Codec HEVC Profil Main 10 Level 153 Auflösung 3840x1608 Seitenverhältnis 160:67 Anamorph Nein Interlaced Nein Bildrate 23,976 Bitrate 13.375 kbps Videobereich HDR Primärfarben bt2020 Farbraum bt2020nc Farbtransfer smpte2084 Bit-Tiefe 10 bit Pixelformatyuv 420p10le Referenz-Frames 1 Is NOT found using the Filter: Title 4K HEVC Codec HEVC Profil Main 10 Level 153 Auflösung 3840x1600 Seitenverhältnis 2.40:1 Anamorph Nein Interlaced Nein Bildrate 23,976 Bitrate 16.475 kbps Videobereich HDR Primärfarben bt2020 Farbraum bt2020nc Farbtransfer smpte2084 Bit-Tiefe 10 bit Pixelformat yuv420p10le Referenz-Frames 1 Another Question I have is: Can I somehow select which Version is preselected if I have multiple versions of a film? I for example I name them film1 - dvd and film1 - 4k it preselects the 4k version (which I want) but if I name them film1 - 4k and film1 - bluray it preselects the bluray version. Regards
Luke 42203 Posted March 29, 2021 Posted March 29, 2021 Hi, it's looking for a minimum width of 3800. Is it still not showing up? Quote Another Question I have is: Can I somehow select which Version is preselected if I have multiple versions of a film? I for example I name them film1 - dvd and film1 - 4k it preselects the 4k version (which I want) but if I name them film1 - 4k and film1 - bluray it preselects the bluray version. Currently there is no way to control this, but it's an area we'll likely look to improve in future updates.
