Guest Posted March 24, 2021 Posted March 24, 2021 Hello, unfortunately I do not have any sound with some files when viewing them over WAN on my FireTV device. The files all have AC3 audio and they all play fine on: - browser (WAN and LAN) - FireTV (same device but different app) - emby for kodi - VLC What can I do to have audio with these files? The next time I have access to this FireTV I will open the SFN window and get logs and further information.
rbjtech 5345 Posted March 24, 2021 Posted March 24, 2021 Which Gen of FireTV stick ? I have noticed and reported that the Gen2 FireTV stick is not recognising AC3, so it is converting to AAC (which plays, but it should not need to do this). This could be related. Are any ffmpeg logs generated when you play the items with the failed Audio ?
ebr 16338 Posted March 24, 2021 Posted March 24, 2021 Hi. How have you set the audio settings in the Fire TV settings themselves? It is possible on these devices to set those in such a way that you will not get any audio if you don't have the proper equipment.
Guest Posted March 24, 2021 Posted March 24, 2021 6 hours ago, rbjtech said: Which Gen of FireTV stick ? I have noticed and reported that the Gen2 FireTV stick is not recognising AC3, so it is converting to AAC (which plays, but it should not need to do this). This could be related. Are any ffmpeg logs generated when you play the items with the failed Audio ? I am using a Gen 1 Stick. Yes, there are logs - I attached the one from my last test. Just a few seconds to test some settings I changed in the client and the FireTV Stick - but no sound. 6 hours ago, ebr said: Hi. How have you set the audio settings in the Fire TV settings themselves? It is possible on these devices to set those in such a way that you will not get any audio if you don't have the proper equipment. I changed almost every setting but reverted them back to standard as none of them changed anything. Audio plays fine with the same video using a different client on the same FireTV stick. ffmpeg-remux-6934d24b-5021-49be-a65b-731e966953df_1.txt
ebr 16338 Posted March 24, 2021 Posted March 24, 2021 Hi. The server is converting to 5.1 AAC - which isn't going to work. In the app playback settings, there is an "Audio" option. Try setting that to "Mix down to stereo".
Guest Posted March 24, 2021 Posted March 24, 2021 13 minutes ago, ebr said: Hi. The server is converting to 5.1 AAC - which isn't going to work. In the app playback settings, there is an "Audio" option. Try setting that to "Mix down to stereo". Yes, I did that as I read that somewhere here - still no sound Or do I have to restart the app after changing that option?
ebr 16338 Posted March 24, 2021 Posted March 24, 2021 No, you don't have to restart the app but it sounds like maybe restarting the device might be something to try. What is all the equipment involved and how is it connected?
Guest Posted March 24, 2021 Posted March 24, 2021 The device is restarted every day (power on/off cycle). But I will change the setting and directly afterwards restart the device. There's only the FireTV and a TV - nothing more. The FireTV is directly attached to the TV via HDMI. LAN/WAN via WiFi
rbjtech 5345 Posted March 25, 2021 Posted March 25, 2021 (edited) 17 hours ago, ebr said: Hi. The server is converting to 5.1 AAC - which isn't going to work. In the app playback settings, there is an "Audio" option. Try setting that to "Mix down to stereo". 5.1 AAC should work ? It's not desirable as AC3 should work directly - but there is an issue with the FireTV recognising AC3 - Same issue on the Gen2. https://developer.amazon.com/docs/fire-tv/device-specifications-fire-tv-stick.html?v=ftvstickgen1 I note the first Audio track is German - followed by an English track. In Audio/Subtitle settings on the client, there is a 'Preferred Audio Language' and a 'Play default Audio Track regardless of Language' - have you set these options ? Edited March 25, 2021 by rbjtech
ebr 16338 Posted March 25, 2021 Posted March 25, 2021 25 minutes ago, rbjtech said: 5.1 AAC should work ? Not on a 1st gen Fire stick I'm afraid - depending on what the stick is plugged into. 1
Guest Posted March 25, 2021 Posted March 25, 2021 4 hours ago, rbjtech said: I note the first Audio track is German - followed by an English track. In Audio/Subtitle settings on the client, there is a 'Preferred Audio Language' and a 'Play default Audio Track regardless of Language' - have you set these options ? I am not sure about the first one but I've set the latter option. It doesn't matter which audio stream is selected - there's no sound with either of them.
Luke 42246 Posted March 29, 2021 Posted March 29, 2021 @Razorblade are you still having an issue with this? Have you checked the fire tv audio settings?
Guest Posted March 29, 2021 Posted March 29, 2021 @Luke Yes, I do but I did not have the opportunity to check the audio settings, yet. I'll do so on Wednesday evening and report back. I will check "Mix down to stereo" and both options 'Preferred Audio Language' and a 'Play default Audio Track regardless of Language' and do a restart of the stick. Do you need any additional log files?
ebr 16338 Posted March 30, 2021 Posted March 30, 2021 17 hours ago, Razorblade said: I will check "Mix down to stereo" and both options 'Preferred Audio Language' and a 'Play default Audio Track regardless of Language' and do a restart of the stick. Hi. He means the audio setting in the Fire stick itself. Thanks.
Guest Posted March 30, 2021 Posted March 30, 2021 Yes, I did check these settings and they should be fine as the same files are playing fine using a different app
ebr 16338 Posted March 30, 2021 Posted March 30, 2021 27 minutes ago, Razorblade said: Yes, I did check these settings and they should be fine as the same files are playing fine using a different app Exactly how are they set?
Guest Posted April 1, 2021 Posted April 1, 2021 Hi, sorry, I first had to check and get all the requested information. Audio settings in the Stick are set as follows: Audio Output set to "Auto" Changing to "Downmix" did not change anything Dolby Digital Output set to DD Plus Auto Opening the SFN window tells me that it's transcoding because of unsupported audio format Player: exoplayer Method: Direct Stream Type: HLS Video Codec: H264 (direct) Audio Codec: AAC Channels: 5.1 Media Information: Container: mkv Video Codec: H264 Audio Codec: DOLBY Channels: 5.1 Do you need any further information?
ebr 16338 Posted April 1, 2021 Posted April 1, 2021 1 hour ago, Razorblade said: Changing to "Downmix" did not change anything Are you positive? Because that should stop it from converting on the server and decode and downmix it locally...
Guest Posted April 2, 2021 Posted April 2, 2021 13 hours ago, ebr said: Are you positive? Yes, I absolutely am. I did change this multiple times and checked multiple files with that setting. I even changed this setting before coming here and posting this issue. 13 hours ago, ebr said: Because that should stop it from converting on the server and decode and downmix it locally... This is also what I thought.
ebr 16338 Posted April 2, 2021 Posted April 2, 2021 Can you play something for a few seconds with that option enabled and then send a log from the app?
Guest Posted April 5, 2021 Posted April 5, 2021 @ebr Yes, I will create these log files and report back as soon as I am back.
Luke 42246 Posted April 6, 2021 Posted April 6, 2021 On 4/5/2021 at 11:09 AM, Razorblade said: @ebr Yes, I will create these log files and report back as soon as I am back. Great, thanks !
Guest Posted April 10, 2021 Posted April 10, 2021 (edited) @Luke @ebr Hi, I just sent/uploaded the debug logfiles. I played an episode of "The 100", the logged in user was embyuser and the time was around 10:55 UTC-5 Please let me know whether you need further information or log files. Edit: Oh, and of course, I enabled the "Downmix" option Edited April 10, 2021 by Razorblade
Solution ebr 16338 Posted April 10, 2021 Solution Posted April 10, 2021 Okay, the system is reporting no support for Dolby and that is causing it to convert on the server in that version. The next version of the app will behave differently and decode it locally. There is also some sort of network issue as there was a timeout at one point during your playback which cause another fallback to transcoding. E/EventLogger( 8231): internalError [eventTime=51.66, mediaPos=0.00, window=0, period=0, loadError] E/EventLogger( 8231): com.google.android.exoplayer2.upstream.HttpDataSource$HttpDataSourceException: Unable to connect to https://xxxxx/emby/videos/93243/hls1/main/0.ts?DeviceId=ce73dc628741dae8&MediaSourceId=fe596cb4f917052c4ae620f5fc2d9722&PlaySessionId=d0deadf3e3494e428e84442aa473542a&api_key=2b6a83b8db934346974957c5a23ad185&VideoCodec=h264,mpeg2video&AudioCodec=aac_latm,mp4a_latm,aac,mp3&VideoBitrate=73259411&AudioBitrate=384000&MaxHeight=1080&AudioStreamIndex=1&SubtitleMethod=Encode&CopyTimestamps=true&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=41&aac_latm-audiochannels=8&mp4a_latm-audiochannels=8&aac-audiochannels=8&mp3-audiochannels=8&TranscodeReasons=AudioCodecNotSupported ... E/EventLogger( 8231): Caused by: java.net.SocketTimeoutException: Read timed out 1
Guest Posted April 12, 2021 Posted April 12, 2021 Hi, Thank you very much for looking into this. Yes, I already noticed some networking issues and I am trying to find out why. Do you know when the new version will be available?
