Emby-xuxin 0 Posted March 24, 2021 Posted March 24, 2021 I added some audio book to Emby server on NAS and use Emby IOS to listen on iPhone. However, I have no idea how to set up the App Store linseed track progress so I can continue from last listen... thank you.
mrfragger 39 Posted March 24, 2021 Posted March 24, 2021 Settings Home Screen Continue Listening If you have that you should see it. I recommend setting in the audiobook library resume to 1% instead of the default 5% and to played to 100% from the default 90%.
Emby-xuxin 0 Posted March 24, 2021 Author Posted March 24, 2021 Thank you for the reply. Is this a Emby Premier function? On my “setting-home screen”, I can only pick up which to show on different section of the Home Screen, like “continue to watch”, “continue to listen”, “New added”, etc. I cannot find the playback screen as you attached. BTW, I just unblock the play function, but not Emby Premier user yet. thanks again for your help and looking forward to your further explanations.
Spaceboy 2573 Posted March 24, 2021 Posted March 24, 2021 3 minutes ago, Emby-xuxin said: Thank you for the reply. Is this a Emby Premier function? On my “setting-home screen”, I can only pick up which to show on different section of the Home Screen, like “continue to watch”, “continue to listen”, “New added”, etc. I cannot find the playback screen as you attached. BTW, I just unblock the play function, but not Emby Premier user yet. thanks again for your help and looking forward to your further explanations. its in the library config after you have enabled advanced settings
