Pimp1310 1 Posted March 21, 2021 Author Posted March 21, 2021 (edited) 8 minutes ago, quickmic said: ok, then use the pattern of my (native) link, adapt it and try. Probably you need your API-Key/token, and NO it cannot help you with that. It's unique. Probably grab it from the Emby server UI when you play a video. btw, I'm afk now, based in Europe, and must work tomorrow  maybe I heard myself wrong. I called the Kodi Json Rpc, this also works with items such as title rating etc. without problems. with fanart I get the path 127.0.0.1/XXXXXX from the kodi Json rpc. now i just have to have a working path for the fanart so that i can access it from my openhab. Edited March 21, 2021 by Pimp1310
quickmic 1709 Posted March 22, 2021 Posted March 22, 2021 (edited) That's not that easy. If you query the images via Kodi json, you must manipulate the pathes"manually" e.g. via script. You cannot just drop the URL. It will also not work for with nfs network pathes. patter is: http(s)://myserverIP:PORTNUMBER/emby/Items/944665/Images/Backdrop/0?EnableImageEnhancers=True&Tag=d7b780f0ed288afcf1767b4ac5a28718 Â Â Edited March 22, 2021 by quickmic
Pimp1310 1 Posted March 22, 2021 Author Posted March 22, 2021 9 hours ago, quickmic said: That's not that easy. If you query the images via Kodi json, you must manipulate the pathes"manually" e.g. via script. You cannot just drop the URL. It will also not work for with nfs network pathes. patter is: http(s)://myserverIP:PORTNUMBER/emby/Items/944665/Images/Backdrop/0?EnableImageEnhancers=True&Tag=d7b780f0ed288afcf1767b4ac5a28718   yeah, i fall back to the kodi DB without Emby and it works perfekt. of course i must manupulate the path.  from image://https://image.tmdb.org/t/p/original/mGVrXeIjyecj6TKmwPVpHlscEmw.jpg/ to https://image.tmdb.org/t/p/original/mGVrXeIjyecj6TKmwPVpHlscEmw.jpg  i removed the "image://" and the "/" at the end.  i try it with emby again. 1
quickmic 1709 Posted March 22, 2021 Posted March 22, 2021 Yes, cause the data are coming from the internet. This link is accessible everywhere (and no login required). Emby server is a local Webserver (unless you expose Embyserver to the internet as well)
Pimp1310 1 Posted March 22, 2021 Author Posted March 22, 2021 (edited) 15 minutes ago, quickmic said: Yes, cause the data are coming from the internet. This link is accessible everywhere (and no login required). Emby server is a local Webserver (unless you expose Embyserver to the internet as well) Yes this example. But i had path with smb:// too, and they work the same way.  I can open it in my openhab. Lauter i give you a example.  Iam not at home.  Edited March 22, 2021 by Pimp1310
quickmic 1709 Posted March 22, 2021 Posted March 22, 2021 (edited) smb -> Yes, if you have access via network share (and login credentials) Anyway I know it works. It also works with Emby server, but also mentioned. It's not that easy with Emby server. This is not a drag and drop thingy if you wanna access Emby server via links from Kodi. Â Edited March 22, 2021 by quickmic 1
