NoEmbyNoFun 1 Posted March 21, 2021 Posted March 21, 2021 Hello all I'd like to update an item (a movie) using the code pattern from PenkethBoy ( Setting Folder Sort Sequence via API - Developer API - Emby Community ) The information is fetched using GET /emby/{UserId}/items/{ItemId}. Then exactly two pieces of information are changed: UserData.PlayCount and UserData.Played. Then the information should be updated using POST /emby/items/{ItemId}. # edit item $item.UserData.Played = $true $item.UserData.PlayCount = 1 # update item $url = $es + "/Items/73667?api_key=" + $ac $result = Invoke-Webrequest -uri $url -Method POST -Body ( $item | ConvertTo-Json ) -ContentType "application/json; charset=utf-8" # returns StatusCode : 204 StatusDescription : No Content Content : {} ... Unfortunately this POST does not work as hoped. It returns 204 with no content and the item is not updated. In the Swagger UI the code 204 is not explained. In this forum I didn't find anything about it. Also in the wiki I found no hints regarding updating of items. What am I missing? (The user has the right to manage the emby server). Is there any further documentation? Many thanks in advance for any hint. Dani (Environment: Emby 4.5.4.0, Powershell-Script on Windows 10)
roaku 842 Posted March 21, 2021 Posted March 21, 2021 (edited) 204 is a status that means everything went fine. The difference between it and 200 is that there will be no content in the response. Are you sure the item isn't updated? Edited March 21, 2021 by roaku
NoEmbyNoFun 1 Posted March 21, 2021 Author Posted March 21, 2021 Unfortunately yes, re-query of the item still shows it as not watched. Also using the website shows the movie as not seen.
PenkethBoy 2068 Posted March 21, 2021 Posted March 21, 2021 (edited) did you pull down the FULL item record first and update that - as it wont work if you dont also not sure updating user data via an item will work that way - might but not tried it Edited March 21, 2021 by PenkethBoy
NoEmbyNoFun 1 Posted March 21, 2021 Author Posted March 21, 2021 Yes, I pulled down the full item record with $url = $es + "/Users/" + $uid + "/Items/73667" + "?api_key=" + $ac $result = Invoke-WebRequest -Uri $url -Method GET -ContentType "application/json" $item = $result.Content | ConvertFrom-Json Is there another way than "POST /item/{ItemId}" to update an item?
Luke 42239 Posted March 22, 2021 Posted March 22, 2021 Have you tried comparing your http request to what the web app sends when using the metadata editor? You can do this by following the network requests in the browser debugger.
NoEmbyNoFun 1 Posted March 22, 2021 Author Posted March 22, 2021 17 hours ago, Luke said: Have you tried comparing your http request to what the web app sends when using the metadata editor? You can do this by following the network requests in the browser debugger. Thanks for the hint, the metadata editor doesn't show the fields concering the play state. Thanks to your hint I saw that the endpoint "/Users/{UserId}/PlayedItems/{Id}" is used for the user play state. I'll try it with that one. To be continued.
NoEmbyNoFun 1 Posted March 22, 2021 Author Posted March 22, 2021 Finally, it worked with the endpoint "POST /Users/{UserId}/Items/{ItemId}/UserData". Thanks a lot for all hints. (Topic can be closed.)
