LakersFan 2 Posted March 21, 2021 Posted March 21, 2021 Hello, I am running the plugin VirtualTV. The live TV guide works fine on Windows computers, but has "No Data" in the guide on the first 12 channels on my 2 Fire TVs. I am using the Emby app. If I click the channel, it still plays. It's just that the guide itself is not populating. There is no seemingly obvious way to get them working again. I've tried clearing the cache on the app, refreshing the guide data and reaching out to the plugin dev, who suggested I try this Android TV forum. I've attached my most recent log. Is this something one of you can help out with? Thank you! embyserver.txt
ebr 16338 Posted March 21, 2021 Posted March 21, 2021 8 hours ago, LakersFan said: I am running the plugin VirtualTV. ... but has "No Data" in the guide on the first 12 channels on my 2 Fire TVs Are those channels from the plug-in or from "real" live TV?
ebr 16338 Posted March 21, 2021 Posted March 21, 2021 And if you view them in the web app guide, the programs show there?
ebr 16338 Posted March 23, 2021 Posted March 23, 2021 And, if you scroll down a ways and then scroll back up, do they appear?
ebr 16338 Posted March 24, 2021 Posted March 24, 2021 Also, is there anything special about the channels that have this problem vs the ones that do not? Do you have a "normal" Live TV tuner setup and, if so, does it exhibit this problem at all?
LakersFan 2 Posted March 25, 2021 Author Posted March 25, 2021 Hey guys, Yes, this is a consistent issue. The issue is on both my Fire TV’s but not on my web based Windows PC nor my iPad Emby app. There is nothing special about these channels. They are a simple playlist; generally a playlist of timeframe (ie. 2018-2020) and excludes certain genres such as animation and holiday. But these same options are on those that work. I do not have another tuner or setup involving Live TV. I can post a bunch of screenshots or more logs (detailed) if it helps. Thanks!
Luke 42246 Posted March 25, 2021 Posted March 25, 2021 15 hours ago, LakersFan said: Hey guys, I can post a bunch of screenshots or more logs (detailed) if it helps. Thanks! Hi, yes please, thanks !
LakersFan 2 Posted March 26, 2021 Author Posted March 26, 2021 Here's pics of what I'm seeing https://imgur.com/a/akmV5NQ 1. Channels 100-107 on my PC 2. Channels 100-106 on my Fire TV 3. Channels 109-114 on my PC 4. Channels 109-114 on my Fire TV Here's a log with debug logging on - https://pastebin.com/7B9wSRW5 Really hope this helps!
ebr 16338 Posted March 26, 2021 Posted March 26, 2021 These are channels created by the plug-in but they have real channel names and logos?
LakersFan 2 Posted March 26, 2021 Author Posted March 26, 2021 Yes, that is correct. They are virtual channels.
ebr 16338 Posted March 27, 2021 Posted March 27, 2021 But where did those channel names and logos come from? They look like "real" channels. I'm wondering if the system is confused looking for data for those real channels.
LakersFan 2 Posted March 27, 2021 Author Posted March 27, 2021 They come from the plug-in. I can name the channel whatever I want (HBO for example) and there’s a link in the thread with different logos from actual stations. So in order to get the feel of an actual guide, I name the channels with actual channel names (nerdy, I know lol). But it’s actually a pretty cool app as I tend to watch movies I otherwise probably wouldn’t pick. So last night I deleted my entire configuration file for the plug-in and started from scratch. I created three “channels”, cleared my cache and refreshed the guide. So far this morning those channels are still populating the guide as expected. Maybe this whole time it was a corrupt configuration file? If so, I apologize for wasting anyone’s time in this thread. It was just weird that the guide issues only happened on the Fire tv’s. I’ll be back if the problem returns, but at least for the last 10 hours it seems to be working. Thanks guys.
ebr 16338 Posted March 27, 2021 Posted March 27, 2021 Okay. Please let us know if you run into this again.
