Carlo 4561 Posted April 4, 2021 Posted April 4, 2021 I watch a few partial movies and one in full with no glitches at all. Are you using wifi internally?
DanielFrank 11 Posted April 6, 2021 Author Posted April 6, 2021 On 04/04/2021 at 22:51, cayars said: I watch a few partial movies and one in full with no glitches at all. Are you using wifi internally? No, no WiFi, only LAN.
Carlo 4561 Posted April 6, 2021 Posted April 6, 2021 Are you rocking more than one router? Sharing GB with different computers? It's strange that it streams fine out the WAN port half way around the world but can't stream locally properly. So that pretty much eliminates the Emby Server as being the issue and seems to indicate it's a local network issue.
pwhodges 2028 Posted April 6, 2021 Posted April 6, 2021 Are you using your external IP address/domain name to access your server within your network? If so, it could be that having to use loopback through the router is causing the issue. Paul 1
