PINKISH 2 Posted March 20, 2021 Posted March 20, 2021 Hi, so i'm running emby on windows 10, the transcoding temp were using 250gb a few month ago, now 100gb, It never cleans itself, what should i do to fix it embyserver.txt
Abobader 3485 Posted March 20, 2021 Posted March 20, 2021 Hello PINKISH, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Happy2Play 9802 Posted March 20, 2021 Posted March 20, 2021 (edited) 5 minutes ago, PINKISH said: Hi, so i'm running emby on windows 10, the transcoding temp were using 250gb a few month ago, now 100gb, It never cleans itself, what should i do to fix it embyserver.txt 33.85 MB · 0 downloads There is not task for this on a system that runs continuously. A restart of Emby will clean these abandoned files up. One reason there is a Request to bring back the Restart plugin. Edited March 20, 2021 by Happy2Play
PINKISH 2 Posted March 20, 2021 Author Posted March 20, 2021 3 minutes ago, Happy2Play said: There is not task for this on a system that runs continuously. A restart of Emby will clean these abandoned files up. One reason there is a Request to bring back the Restart plugin. But i've restarted emby recently, nothing was cleaned
Luke 42203 Posted March 23, 2021 Posted March 23, 2021 HI there, did you set a custom transcoding temp folder path?
