swehawk 7 Posted March 20, 2021 Posted March 20, 2021 I can´t get the Emby app to display the next TV-episode(s) on the homescreen, neither in the "Next channel" nor in the Emby-channel! However, partially watched movies are displayed in the "Next-channel". I enabled the Emby-channel but only for TV-episodes but Android says the channel is empty. Within the Emby app the next TV-episodes are displayd correctly. Is this a known bug or am I missing anything here? Running latest stable version of app on Mibox 4S and latest stable server on windows.
ebr 16338 Posted March 20, 2021 Posted March 20, 2021 Hi. Can you please show us exactly what you enabled or disabled and then also confirm your version numbers for both app and server? Thanks.
swehawk 7 Posted March 29, 2021 Author Posted March 29, 2021 The windows server is 4.5.4.0 and the app is 1.8.54g. In AndroidTV channel settings : Next channel, I enabled Emby Emby channel, I enabled TV-episodes
ebr 16338 Posted March 30, 2021 Posted March 30, 2021 17 hours ago, swehawk said: In AndroidTV channel settings : Next channel, I enabled Emby Emby channel, I enabled TV-episodes Can you provide a screen shot of those settings? Thanks.
swehawk 7 Posted April 7, 2021 Author Posted April 7, 2021 All of a sudden the Emby channel showed up! I marked two tv-series as unwatched and then the first episode of each as watched. Then, back to the Android homescreen I found the Emby channel displaying the correct next episodes. I have watched a few TV-series before and in Emby the next episodes were dispayed under Next Up, but nothing in the Emby channel! In the Next channel however, still no Emby content is displayed! The language is swedish so Next = Nästa, Channels = kanaler.
ebr 16338 Posted April 7, 2021 Posted April 7, 2021 Hi. If you are showing our dedicated Next Up TV channel then I don't think we put those same items into the standard "Play Next" channel. If you right click an item in Emby and select "Add to play next", does it show up there?
