Remote Connection timing out
dc07342@gmail.com
I know you've had this multiple times from other people but I'm new to this so..... When I first installed Emby back last summer I had no problems and it worked until just recently for remote access viewing.  I have no problems internally and can watch from various devices the content on my drives.
I have glofiber with 1gig up and 1gig down.
I have a Linksys Smart wifi router with UPnP enabled and port forwarding for ports 8096 and 8920 (had no port forwarding and the Enable Automatic Port Mapping turned on but that didn't work either), I also tried Enable Automatic Port Mapping and port forwarding but no good on that either.
I am using an HP Spectre x2 Detachable N5S14UA running windows 10 home 64 -bit for the computer running the Emby Server and it is hard wired to my network.
I have read most of the applicable articles on setting up and still nothing.(https://support.emby.media/support/solutions/articles/44002137137-remote-setup)
It sounds like you did most of the setup.
What happens if you go out to canyouseeme and test ports 8096 and 8920?
BTW, unless you have a domain and installed a cert don't bother with port 8920 as secured SSL can't be used without a cert.
From your Emby Server if you do a tracert (traceroute) to 8.8.8.8 what do hops 2 and 3 look like?  Do either of these hops start with 172, 192 or 10?
dc07342@gmail.com
canyouseeme gives me the standard
Error: I could not see your service on 204.111.xxx.xx on port (8096)
Reason: Connection timed out
I used Telnet on my computer to check the open port and it says its open.
Tracert show this for hops 2 and 3
  2     3 ms     1 ms     2 ms  204.111.124.2
  3     1 ms     1 ms     2 ms  10.24.0.221
I have uninstalled Emby and reinstalled, reloaded libraries etc. and it made no difference.
Edited by Happy2Play
Edited WAN address
OK you're third hop is using a private IP address space which almost always means your ISP has you behind a CGNAT (carrier grade NAT).  In that environment you will not be able to get Emby running remotely as you don't have a true IP on the Internet.
Check with you ISP and see if you can get a public IP or static IP.
dc07342@gmail.com
Talked to ISP and they changed me from private to public. The new tracert is
  2     1 ms     2 ms     1 ms  204.111.39.2
  3     4 ms     5 ms     4 ms  204.111.0.145
Canyouseeme now says
Success: I can see your service on 204.111xx,xx on port (8096)
Your ISP is not blocking port 8096
Your IP:
Port to Check:
Check Port
I have restarted the Emby Server and it shows the new IP configuration. I went to network settings and turned on the Allow Remote connections to this Emby Server and Enable automatic p-ort mapping.
I turned Wi-Fi off on my cell phone and tried to connect. Didn't work. Uninstalled and reinstalled the app on my phone, turned off the Wi-Fi again and still no luck.
Telnet shows port is open.
In Windows Defender, the Allow apps to communicate through Windows Defender Firewall is set to private and  public.
Next Step?????
Edited WAN Address
Can you post a picture of the port forwarding you have setup?
dc07342@gmail.com
Follow up: After all of this it just took sometime for all of the pieces to work together. For whatever miracle the Emby Server is now open to remote connection. I had my son in another town try it out and he said he could connect just fine. I turned off the wi-fi on my phone after about 15 min of my last post and everything worked fine.
Thanks for all of your help in this matter.
  • Like 1
Perfect, glad you got it working!
