rjow2021 4 Posted March 19, 2021 Posted March 19, 2021 (edited) I'm setting up emby, with the intention of moving away from Plex within a few days. I can get this all set up and running but I'm having issues with the posters for the files. And seeing as the whole family rely on this I'd like to get this sorted before migrating. I'm pointing emby to the same files as Plex but having to adjust the filenames to get the correct metadata. But I'm struggling with a few films. There is some Lego DC Comic files that just will not get the right poster. Most of the other files are ok, and I'm realising the different way that emby reads content, but cannot get these fixed. Is there any tips regarding files that won't refresh with the correct metadata? Edited March 19, 2021 by slinkyrich
Abobader 3485 Posted March 19, 2021 Posted March 19, 2021 Hello slinkyrich, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution rbjtech 5337 Posted March 19, 2021 Solution Posted March 19, 2021 (edited) Hi, This document below details the naming standards that emby uses. https://support.emby.media/support/solutions/folders/44000764515 If for some reason they are still not picked up, then I would check the source metadata sites directly to see how they have named it and check the year etc (tmdb, tvdb etc) If you have a REALLY stubborn file - then you can actually add the provider id into the foldername by including in square brackets - ie FolderName (2021) [tvdbid=123456] I hope this helps. Edited March 19, 2021 by rbjtech 1
rjow2021 4 Posted March 19, 2021 Author Posted March 19, 2021 (edited) Excellent! Thank you very much for your help. Might even get this all completed for the family to start using Emby tonight! Edited March 19, 2021 by slinkyrich 1
rjow2021 4 Posted March 19, 2021 Author Posted March 19, 2021 EDIT: Seems to have worked with all the other stubborn files except from the Lego DC files. Tried everything suggested. I'm thinking it's the settings on the server. Either way, I can deal with these files afterwards, they have plenty to watch. 1
rbjtech 5337 Posted March 20, 2021 Posted March 20, 2021 23 hours ago, slinkyrich said: EDIT: Seems to have worked with all the other stubborn files except from the Lego DC files. Tried everything suggested. I'm thinking it's the settings on the server. Either way, I can deal with these files afterwards, they have plenty to watch. If you can give example file names / structure of the Lego DC ones, we may be able to help you solve these last few. 1
rjow2021 4 Posted March 20, 2021 Author Posted March 20, 2021 4 minutes ago, rbjtech said: If you can give example file names / structure of the Lego DC ones, we may be able to help you solve these last few. I managed to solve the issue clicking on the 3 dots in the poster art and using identify. Then I go to www.imdb.com, and type in the name, Year, and IMDb ID in the URL for the film. It's picked them up perfectly.
Luke 42203 Posted March 21, 2021 Posted March 21, 2021 12 hours ago, slinkyrich said: I managed to solve the issue clicking on the 3 dots in the poster art and using identify. Then I go to www.imdb.com, and type in the name, Year, and IMDb ID in the URL for the film. It's picked them up perfectly. Thanks for the feedback.
