NoEmbyNoFun 1 Posted March 18, 2021 Posted March 18, 2021 Hello all I would like to get the information about exactly one movie using the API /Users/{UserId}/Items, using Powershell 5.1 on Windows 10. Authentication as a user works fine. Searching directly for the title works fine and returns two items. # Code: $mu = 'http://myembyserver:8096/users/' + $uid + '/items?SearchTerm="Southpaw"&Recursive=true&api_key=' + $apikey Invoke-WebRequest -Uri $mu -Method Get -ContentType "application/json" # Result: StatusCode : 200 StatusDescription : OK Content : {"Items":[{"Name":"Southpaw","ServerId":"721f2a80d300464984d9a0e141800e84","Id":"30969","RunTimeTic ks":74554990000,"IsFolder":false,"Type":"Movie","UserData":{"PlaybackPositionTicks":0,"PlayCount":0 ,"... However, when I use the parameter AnyProviderIdEquals 0 items are returned. # Code: $mu = 'http://myembyserver:8096/users/' + $uid + '/items?AnyProviderIdEquals="imdbid.tt1798684"&Recursive=true&api_key=' + $apikey Invoke-WebRequest -Uri $mu -Method Get -ContentType "application/json" # Result: StatusCode : 200 StatusDescription : OK Content : {"Items":[],"TotalRecordCount":0} RawContent : HTTP/1.1 200 OK Access-Control-Allow-Headers: Accept, Accept-Language, Authorization, Cache-Control, Content-Disposition, Content-Encoding, Content-Language, Content-Length, Content-MD5, Content-Rang... Also with the tmdbid (tmdbid.307081) the result looks the same. Even if I try to use this parameter in the Swagger UI, I get no result. What am I doing wrong? Many thanks in advance for your advice. Many greetings, Dani
PenkethBoy 2068 Posted March 18, 2021 Posted March 18, 2021 (edited) not tried but =tt1798684 without the imdbid Edited March 18, 2021 by PenkethBoy
NoEmbyNoFun 1 Posted March 18, 2021 Author Posted March 18, 2021 Thanks PenkethBoy, unfortunately there is no change in the result, no records found. $mu = 'http://myembyserver:8096/users/' + $uid + '/items?AnyProviderIdEquals="tt1798684"&Recursive=true&api_key=' + $apikey Invoke-WebRequest -Uri $mu -Method Get -ContentType "application/json" StatusCode : 200 StatusDescription : OK Content : {"Items":[],"TotalRecordCount":0} RawContent : HTTP/1.1 200 OK Access-Control-Allow-Headers: Accept, Accept-Language, Authorization, Cache-Control, Content-Disposition, Content-Encoding, Content-Language, Content-Length, Content-MD5, Content-Rang...
PenkethBoy 2068 Posted March 18, 2021 Posted March 18, 2021 ok - never used that end point but can you explain what you are trying to achieve in detail and why are you using this endpoint specifically?
NoEmbyNoFun 1 Posted March 18, 2021 Author Posted March 18, 2021 Of course, my Emby movie library contains about 1200 movies. I have an external list of about 800 movies that we have already seen. This list contains the IMDB ID and TMDB ID of the movies we have seen. Now, using this list, I want to mark these 800 movies as seen in Emby. Pseudo-Code for the script: Read list Loop over all entries Search film in emby Update UserData: PlayCount, LastPlayedDate and Played Ende Loop
PenkethBoy 2068 Posted March 18, 2021 Posted March 18, 2021 do all your movies in emby have a tmdb id?
roaku 842 Posted March 18, 2021 Posted March 18, 2021 Looking at the api docs, you should be using 'imdb' for your prefix, not 'imdbid'.
PenkethBoy 2068 Posted March 18, 2021 Posted March 18, 2021 off top of my head i would approach this by load your list of watched movies pull back all movies from emby (1200 is not that big) compare the tmdb id's then pull the full record for a matched movie (as you cant do a partial update) - update and save as only needs to be done once
NoEmbyNoFun 1 Posted March 18, 2021 Author Posted March 18, 2021 Thanks, that's how it works! $mu = 'http://myembyserver:8096/users/' + $uid + '/items?AnyProviderIdEquals=imdb.tt1798684&Recursive=true&api_key=' + $apikey Invoke-WebRequest -Uri $mu -Method Get -ContentType "application/json" StatusCode : 200 StatusDescription : OK Content : {"Items":[{"Name":"Southpaw","ServerId":"721f2a80d300464984d9a0e141800e84","Id":"30969","RunTimeTicks":7455499000 RawContent : HTTP/1.1 200 OK Access-Control-Allow-Headers: Accept, Accept-Language, Authorization, Cache-Control, Content-Disposition, Content-Encoding, Content-Language, Content-Length, Content-MD5, Content-Rang... Forms : {} Headers : {[Access-Control-Allow-Headers, Accept, Accept-Language, Authorization, Cache-Control, Content-Disposition, Content-Encoding, Content-Language, Content-Length, Content-MD5, Content-Range, Content-Type, Date, Host, Transfer-Encoding, Want-Digest, X-MediaBrowser-Token, X-Emby-Token, X-Emby-Client, X-Emby-Client-Version, X-Emby-Device-Id, X-Emby-Device-Name, X-Emby-Authorization], [Access-Control-Allow-Methods, GET, POST, PUT, DELETE, PATCH, OPTIONS], [Access-Control-Allow-Origin, *], [Content-Length, 780]...} Images : {} InputFields : {} Links : {} ParsedHtml : mshtml.HTMLDocumentClass RawContentLength : 780 I don't know why I used imdbid, sorry for that and thanks again for your support. 1
NoEmbyNoFun 1 Posted March 18, 2021 Author Posted March 18, 2021 (edited) 20 minutes ago, PenkethBoy said: ... pull back all movies from emby (1200 is not that big) compare the tmdb id's ... Is there an easy way (a end point) to pull back all movies with one request or do I have to loop over all libraries? Edited March 18, 2021 by NoEmbyNoFun
PenkethBoy 2068 Posted March 18, 2021 Posted March 18, 2021 yes \items endpoint will do that with includeitemtype=movie and recursive=true or the one you are using if you need to limit by user - it will pull all movies so you may need to limit by parentid to limit by a library use swagger to test it - via "API" link at bottom of dashboard page e.g. http://localhost:8096/emby/Items?Recursive=true&IncludeItemTypes=movie&api_key=<api_key> Might also be time to move to PS 7.1 as latest stable release
NoEmbyNoFun 1 Posted March 19, 2021 Author Posted March 19, 2021 Thanks again, good point . If anyone is interested, I can post the script here. Otherwise the topic can be closed.
nunu22 2 Posted March 27, 2021 Posted March 27, 2021 Hi, i will be interested by the script. on this line : http://localhost:8096/emby/Items?Recursive=true&IncludeItemTypes=movie&api_key=<api_key> is it possible to do it for a user only ? regards.
NoEmbyNoFun 1 Posted March 27, 2021 Author Posted March 27, 2021 Hi nunu22 The script became a bit longer than planned, so I'm happy to make it available here. The script allows a certain Emby user to mark one or more films as watched, based on TMDB ID or IMDB ID. This Emby user needs the right to manage the Emby server. The script requires Powershell, version 5.1, which is automatically included with Windows 10. To get all items for a specific user, I use the endpoint /Users/{UserId}/Items Details can also be found in the Swagger UI. Best regards, Dani EmbySet-Watched.ps1
nunu22 2 Posted March 27, 2021 Posted March 27, 2021 thanks for the sharing ! i'am not familiar with http stuff and i'am discoevring the emby API & swagger UI :) i try to make a script to synchronzied watched item between 2 servers in bash. regards.
nunu22 2 Posted March 29, 2021 Posted March 29, 2021 Hi, I not so far from my little script. I can get movie information from a User from 2 servers and identifying items to set to "Played". i have check NoEmbyNoFun script and see that there is the entry point : /Users/$USER/Items/$ID/UserData/ I don't see the swagger information about this (maybe i have missed something) Never mind, i try to use it to set a movie of a user to Played=true: The code is in Bash : URL=$SERVER_URL"/Users/$USER/Items/$ID/UserData/?api_key=$KEY" curl -X POST "$URL" -H "accept: application/json" -d '{"Played": "true"}' I guess that "UserData" in the URL allows to point directly to a field of the strcuture: { "Name": "ServerId": "Id": "RunTimeTicks": "IsFolder": "Type": "UserData": { <=========================== HERE "PlaybackPositionTicks": 0, "PlayCount": 1, "IsFavorite": false, "LastPlayedDate": "Played": true }, "ImageTags": { "Primary": "Logo": "Thumb": }, "BackdropImageTags": [ ], "MediaType": }, But i have this error : Guid should contain 32 digits with 4 dashes (xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx). I check on the net, but i miss skill on HTTP things If anyone can help ?! regards
PenkethBoy 2068 Posted March 29, 2021 Posted March 29, 2021 not tested but $used in your url would be like this "dbb929563df645b3b95b2c9fd0b28313" but you need to also return a "body" with a json payload - Played true will not work
nunu22 2 Posted March 29, 2021 Posted March 29, 2021 yes $USER is something like you have describe. -d '{"Played": "true"}' won't be considered like a json payload ?
PenkethBoy 2068 Posted March 29, 2021 Posted March 29, 2021 emby does not allow partial updates you need to return the full json as the body
nunu22 2 Posted March 29, 2021 Posted March 29, 2021 So i must read the full item , modify the field and push it ?
nunu22 2 Posted March 30, 2021 Posted March 30, 2021 Hi, i have still error 404. it seems that 404 means that communication is OK with the server but the ressource is not find. I use the entry point : /Users/$USERID/Items/$ITEMID/?api_key=$KEY , but in swagger, i don't see this ressource for POST (only for GET) If i use the URL for a GET it works (i get the json information of the item). But for the POST i have 404 error (and adding -d option), i get in server logs these 2 lines: 2021-03-30 16:54:41.290 Info Server: http/1.1 POST http://xxxxxxxxxxxxxxxxx//Users/a3bf1dbe2f6743c8a65fabbed9ee2537/Items/489/. UserAgent: curl/7.54.0 2021-03-30 16:54:41.290 Info Server: http/1.1 Response 404 to 90.32.21.126. Time: 0ms. http://xxxxxxxxxxxxxxxxxxx//Users/a3bf1dbe2f6743c8a65fabbed9ee2537/Items/489/ What kind of error is generated if a json data to send during a POST is not correct ? could it be 404 ? regards
NoEmbyNoFun 1 Posted March 30, 2021 Author Posted March 30, 2021 Hi nunu22 Some experiences I've made with my script. I don't know what the exact syntax is in Bash, but would like to show some important points using Powershell code. Use the endpoint /Users/$USERID/Items/$ITEMID to get the item you want to update. This seems to work. Extract the userdata from the item. Powershell Code: $ud = $ITEMID.UserData Update the userdata as you like. Powershell Code: $ud.Played = $true Use the endpoint /Users/$USERID/Items/$ITEMID/UserData to update the user data of the item. The body must only contain the user data, not the whole item. Powershell Code: Invoke-Webrequest -uri "/Users/$USERID/Items/$ITEMID/UserData?api_key=$KEY" -Method POST -Body ( $ud | ConvertTo-Json ) -ContentType "application/json; charset=utf-8" The relevant part is "POST -Body ( $ud | ConvertTo-Json )". As you can see only the user data $ud is converted into JSON, not the whole $ITEM. Hope it's of some use. On which platform should your script work? Greetings, Dani
nunu22 2 Posted March 30, 2021 Posted March 30, 2021 thanks for your answer ! i have read your script and by this way i had discover the endpoint /Users/$USERID/Items/$ITEMID/UserData that seems not in swagger. I run my script on a synology NAS. the form of the data that i try to post : { "PlaybackPositionTicks": 0, "PlayCount": 0, "IsFavorite": false, "Played": true } i don't know if the format is OK ?
