myoldvcr 21 Posted March 18, 2021 Posted March 18, 2021 I have one channel that has no guide data. The channel is COZI TV KFKZ-LD channel 35.1. It is not a new channel. I tried mapping the channel but there is no listing for it to select. Thanks.
Solution Carlo 4561 Posted March 19, 2021 Solution Posted March 19, 2021 23 hours ago, myoldvcr said: I have one channel that has no guide data. The channel is COZI TV KFKZ-LD channel 35.1. It is not a new channel. I tried mapping the channel but there is no listing for it to select. What you might want to do is try some other zip codes to see if the guide has the cozi channel. Basically any zipcode in your time zone should work. So you would end up with 2 guides loaded, your original and the other guide used just for Cozi.
