fusrodah26 5 Posted March 18, 2021 Posted March 18, 2021 Hey guys, I've got a lot of older shows and/or lesser known shows that don't have a ton of choices available for subtitles. When I get lucky enough to find one that does have the right words, often times they will be so far off that in the subtitle offset screen I've gone up to about -11500 ms, and that's a lot of mouse clicking. Any way it can be added/adjusted to have the option of just entering a number to start the offset from and then adjust from there as needed? So when all the episodes of a season are that far off, I can start them at say 10,000 ms and do any more necessary fine-tuning from there? Appreciate any feedback on it. Thanks. 1
ebr 16339 Posted March 18, 2021 Posted March 18, 2021 Possibly, but there are tools that can do this for you in the file permanently.
