chupi28123 0 Posted March 18, 2021 Posted March 18, 2021 COMO PUEDO SACAR CANALES QUE NO QUIERO DE MILINK M3U
Carlo 4561 Posted March 18, 2021 Posted March 18, 2021 10 hours ago, chupi28123 said: HOW CAN I REMOVE CHANNELS I DON'T WANT FROM MILINK M3U Hi the best way is to download the M3U file locally and point an Emby tuner at this file. You can then edit this file with notepad or a similar text editor. Each channel is typically 2 lines in most M3U files so you'll typically need to make sure you remove the lines in pairs. There are 3rd party tools you can use such as xTeVe (little bit of learning curve) that can filter based on groups and country codes which can make this process easier but you will need to keep xTeVe running all the time which isn't always the most ideal. Let us know if this helps.
