space2001 18 Posted March 17, 2021 Posted March 17, 2021 (edited) I think I set this up correctly but for some reason even though I have it set for 90 it does not play the next episode. is there anything else I have to do? Edited March 18, 2021 by space2001 1
space2001 18 Posted March 21, 2021 Author Posted March 21, 2021 I have it set to play at 90% but turned off ask.
space2001 18 Posted March 23, 2021 Author Posted March 23, 2021 it asks to play the next episode. I can hit play next but I want it to auto play
TeamB 2440 Posted March 23, 2021 Posted March 23, 2021 Ok sounds like a bug, I will try to reproduce when I get 10 minutes free.
TeamB 2440 Posted March 24, 2021 Posted March 24, 2021 Yes this is a bug 23 hours ago, space2001 said: it asks to play the next episode. I can hit play next but I want it to auto play What version of Kodi are you using 18 or 19?
space2001 18 Posted March 24, 2021 Author Posted March 24, 2021 Using the latest one on Nvidia Shield, I think its 19 or called matrix
TeamB 2440 Posted March 24, 2021 Posted March 24, 2021 Ok, I can have a fix for this version out layer today in the beta build, the only difference between stable and beta will be this fix.
TeamB 2440 Posted March 25, 2021 Posted March 25, 2021 this fix has been released to the beta repo EmbyCon version 1.10.9
