chillbro9393 0 Posted March 17, 2021 Posted March 17, 2021 (edited) Hello on latest Emby Android TV Versions the sound is not getting direct played like it used before on Version tv.emby.embyatv_1.7.54g (DTS Direct) but instead it says in nerd stats (DTS+Local Downmix) which results in very low audio quality. The Audio Setting is set to Auto. Please fix this Also if there could be improvements done to the loading of the covers because its quite laggy and 1.7.54g works just fine with loading covers. thanks Edited March 17, 2021 by chillbro9393
ebr 16338 Posted March 17, 2021 Posted March 17, 2021 Hi. The last sentence confused me a bit. Which version of the app are you running? Also, exactly what equipment is involved?
chillbro9393 0 Posted March 17, 2021 Author Posted March 17, 2021 (edited) i joined the beta android programm and the latest beta android tv version it shows DTS (Software Decode) now. Is that the proper way now?, it seems the quality still isnt 100% clear, a little but muffled also covers seem to be loading normal, i reverted always to this old version because the cover loading was so laggy and becaause of these sound issues the hardware used is this which is basically a mibox in a projector https://www.mi.com/global/mi-smart-compact-projector Edited March 18, 2021 by chillbro9393
chillbro9393 0 Posted March 18, 2021 Author Posted March 18, 2021 The audio settings are missing in the newest beta aswell.
ebr 16338 Posted March 18, 2021 Posted March 18, 2021 So the app is running on the projector and the sound is being produced by the built in speaker? 6 hours ago, chillbro9393 said: The audio settings are missing in the newest beta aswell. Exactly what settings do you see? Are there options for DTS?
chillbro9393 0 Posted March 18, 2021 Author Posted March 18, 2021 there are no options for audio and as i said 1.7.54g is the latest version where DTS (direct) works, after that i tried all versions which result in lower quality and it says Local Downmix or (Software Decode) in latest beta, so changes were made on your side
ebr 16338 Posted March 18, 2021 Posted March 18, 2021 2 hours ago, chillbro9393 said: there are no options for audio Can you show me a screen shot of the playback settings in the app where the audio options should be? Thanks.
chillbro9393 0 Posted March 18, 2021 Author Posted March 18, 2021 (edited) yeah of course, there is nothing in the settings regaring audio Edited March 18, 2021 by chillbro9393
ebr 16338 Posted March 19, 2021 Posted March 19, 2021 Unfortunately, I can't be sure exactly which options I'm looking at there . Can you please play something for just a few seconds on the device and then send a log from the app? Go into settings and enable "Debug Options" and then, during playback, bring up the OSD, go to the "cog" menu and select "Send log...". Then come here and tell me when you did that. Thanks.
