Guest Posted March 17, 2021 Posted March 17, 2021 (edited) This is a little CSS code to help you align your Album Art vertically by percentage, and adjust your bottom-margin... The numbers can be adjusted to your liking and viewing preference. I found that after saving you should restart your browser and go back to see the changes.. div.osdPoster-img { margin: 0; max-height: 60%; margin-bottom: 10%; } Optionally you can hide the song information under the artwork.. h2.videoOsdParentTitle { display: none; } An example.. Before: After: Edited March 17, 2021 by Guest
arrbee99 1836 Posted March 17, 2021 Posted March 17, 2021 Quick hi-jack, cos I'm like that. This is my preferred album art - I should probably get rid of those baby album images on the right as well....
Guest Posted March 17, 2021 Posted March 17, 2021 (edited) A little more difficult .. but totally do-able... I hid those already.. The next thing is to change the CSS so that the area for the player and art extend all the way over.. What I would like to see is it in the form of a slide out drawer that will appear when you mouseover that area of the screen.. 'display: none;' is always cool for those unwanted items..LOL Edited March 17, 2021 by Guest
arrbee99 1836 Posted March 17, 2021 Posted March 17, 2021 I just posted about getting rid of those images. You know how ?
arrbee99 1836 Posted March 17, 2021 Posted March 17, 2021 You mean this ? /* Make Music Backdrop Full Screen and Make Playlist Transparent */ div.backdropContainer.backdropContainer-remotecontrol {right: 0%;} div.upNextBar.upNextBar-static.flex.align-items-center {background: rgba(0,0,0,.33)!important;} div.osdPlaylist.flex.flex-grow.hide.osdPlaylist-hidden {background: rgba(0,0,0,.33)!important;}
Guest Posted March 17, 2021 Posted March 17, 2021 (edited) I was playing with it.. Using Edge and 'Inspect' with notepad.. LOL.. Haven't got the big toys out in a while.. EDIT: Will try this out though awesome.. Edited March 17, 2021 by Guest
arrbee99 1836 Posted March 17, 2021 Posted March 17, 2021 Obviously I kill the album art and brighten the background, but people obviously like different things. The command I use for that also brightens backgrounds for Movies etc as well, which I also like, but....
