sundevil67 30 Posted March 16, 2021 Posted March 16, 2021 I have just a few key channels that are not pulling guide data and was wondering if there was any steps I can take to understand why just those channels are problematic. They work OK when playing live content, but the missing guide data means I'm unable to record. The one that really matters is the following: #EXTINF:-1 tvg-id="yes.network.us" tvg-name="yes.network.us" tvg-type="live" group-title="Sports" tvg-logo="https://media.tv4.live/yes.network.us.png",YES Network US https://tv4.live/api/stream/IPTVusername/IPTVpassword/livetv.epg/yes.network.us.m3u8 Is there anything wrong here that might be responsible for the issue? The odd thing is that it used to work....
kanipek 230 Posted March 16, 2021 Posted March 16, 2021 1 hour ago, sundevil67 said: I have just a few key channels that are not pulling guide data and was wondering if there was any steps I can take to understand why just those channels are problematic. They work OK when playing live content, but the missing guide data means I'm unable to record. The one that really matters is the following: #EXTINF:-1 tvg-id="yes.network.us" tvg-name="yes.network.us" tvg-type="live" group-title="Sports" tvg-logo="https://media.tv4.live/yes.network.us.png",YES Network US https://tv4.live/api/stream/IPTVusername/IPTVpassword/livetv.epg/yes.network.us.m3u8 Is there anything wrong here that might be responsible for the issue? The odd thing is that it used to work.... The station !D for YES is: 46275 for HD 30017 for SD Does that help?
sundevil67 30 Posted March 16, 2021 Author Posted March 16, 2021 5 minutes ago, kanipek said: The station !D for YES is: 46275 for HD 30017 for SD Does that help? Hmmm.... not real sure how that'd work since all of the other IDs are in the format: yes.network.us. I suppose I can try replacing it with those IDs & refresh the guide & see what happens
kanipek 230 Posted March 16, 2021 Posted March 16, 2021 1 minute ago, sundevil67 said: Hmmm.... not real sure how that'd work since all of the other IDs are in the format: yes.network.us. I suppose I can try replacing it with those IDs & refresh the guide & see what happens I will PM you
sundevil67 30 Posted March 17, 2021 Author Posted March 17, 2021 Yes; in a roundabout way, I did manage to get those channels showing up again. I'm not completely sure why what I did worked, but I created a duplicate entry for that channel, and that somehow made the original start showing up...Special thanks to @kanipek for all of the help over PM. 1
Solution BillOatman 597 Posted March 18, 2021 Solution Posted March 18, 2021 Sometimes the source of the guide data has issues for a day or two, then it gets corrected and the data starts showing up again. That could have happened as well.
