cugar 0 Posted March 15, 2021 Posted March 15, 2021 Soy usuario de Plex y he contratado una cuenta premium con Emby para cambiarla por Plex, pero no paro de tener problemas con la conexion remota. Funcionando perfectamente y de buenas a primera no me deja conectar ningun usuario fuera de mi red local sale el mensaje "usuario y contraseña incorrectos" en el mismo servidor tengo Plex y va perfecto
Abobader 3485 Posted March 15, 2021 Posted March 15, 2021 Hello cugar, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
pwhodges 2028 Posted March 16, 2021 Posted March 16, 2021 (edited) Are you trying to log in via the Emby site or specifying your server's url? The first requires you to use your Emby Connect login (same as this forum), and the second requires you to use one of the user logins you have defined in your Emby server. Either way you need to have ensured that access through your router to your server is possible. These two articles will help you check the setting up required for each possibility: https://support.emby.media/support/solutions/articles/44002137137-remote-setup https://support.emby.media/support/solutions/articles/44001160340 Paul Edited March 16, 2021 by pwhodges
