RanmaCanada 502 Posted September 4, 2022 Posted September 4, 2022 Also don't forget that there is a tool on doom9 to change and inject DV profiles. 1
FrostByte 5454 Posted September 4, 2022 Posted September 4, 2022 On 8/31/2022 at 4:41 AM, mrmorrison said: I am writing in this old post just to update information. Sony Bravia TVs (or at least the one I have, A8H - 2020) can play profiles 5 profiles 8 and even 7 MEL (not 7 FEL). Profile 7 must necessarily be in single track (makeMkv). All this tested by me with Emby app for android Sorry if all this has been known for some time and I have written obvious things Thanks. I'm seriously thinking of a Sony for my next TV and glad to see they support DV7 MEL. Couldn't find anything in the user's manual stating that. I sort of figured all new Sony's supported 8.1 though because Sony has their own streaming service Bravia Core which uses profile 8.1 and requires a 115 mbps connection. 1
mrmorrison 22 Posted September 8, 2022 Posted September 8, 2022 On 9/5/2022 at 1:25 AM, FrostByte said: Thanks. I'm seriously thinking of a Sony for my next TV and glad to see they support DV7 MEL. Couldn't find anything in the user's manual stating that. I sort of figured all new Sony's supported 8.1 though because Sony has their own streaming service Bravia Core which uses profile 8.1 and requires a 115 mbps connection. I am happy to have been a help to you. I have to specify that Sony default media player cannot play Dolby Vision. It is necessary to use third-party apps such as Emby (but also some Kodi builds) 1 1
georgiosdelimpasis 0 Posted November 28, 2022 Posted November 28, 2022 On 9/8/2022 at 2:01 PM, mrmorrison said: I am happy to have been a help to you. I have to specify that Sony default media player cannot play Dolby Vision. It is necessary to use third-party apps such as Emby (but also some Kodi builds) My Sony X93J default media player definitely plays Dolby Vision. The Emby app instead does not.
Luke 42245 Posted November 30, 2022 Posted November 30, 2022 On 11/28/2022 at 3:35 AM, georgiosdelimpasis said: My Sony X93J default media player definitely plays Dolby Vision. The Emby app instead does not. @georgiosdelimpasis Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
