Oracle 86 Posted March 13, 2021 Posted March 13, 2021 Title says it all. I've spent the last few months slowly setting up the library how I felt fit, only to just tonight have everything sort of reconfigured without any notice or any action on my part. In fact, tonight, I wasn't even using Emby at all. Now, everything is loading BACK into Emby, it's just frustrating. What caused this? Ive attached a log. The most recent one. New Text Document.txt
Luke 42203 Posted March 13, 2021 Posted March 13, 2021 Hi, what exactly do you mean by reloaded, and why do you think this is happening?
Oracle 86 Posted March 13, 2021 Author Posted March 13, 2021 All of the series are simply being almost re-added into Emby, as if I just added them for the first time.
ebr 16309 Posted March 13, 2021 Posted March 13, 2021 1 hour ago, Arly (Sprinkles) said: All of the series are simply being almost re-added into Emby, as if I just added them for the first time. Hi. What, exactly, is making you think that is happening?
ebr 16309 Posted March 13, 2021 Posted March 13, 2021 It looks like your "H" drive went completely away. What is that drive? A physical disc or a mapped network drive?
ebr 16309 Posted March 14, 2021 Posted March 14, 2021 18 hours ago, Arly (Sprinkles) said: It is a physical HDD. Internal? USB? How is it connected? It might be failing...
Oracle 86 Posted March 14, 2021 Author Posted March 14, 2021 It is connected via USB to my machine. I use an 8-bay DroboPro DAS. It's second hand, and so are a couple are the drives inside, so I wouldn't be surprised. Luckily, I have backups of everything. For right now, the issues seems to have resolved itself and my H drive is back where it should be. Just really curious as to what caused it.
Luke 42203 Posted March 14, 2021 Posted March 14, 2021 It would appear the drive was down or inaccessible during a library scan. In this situation the server does not intend to clear out the contents of the library, but we have seen a few reports here and there where it does occur that we're looking into. Thanks.
