Bueschere 0 Posted March 12, 2021 Posted March 12, 2021 Hi, I dont know for sure where to post this but every time i try to play a movie at 1080p 60mbps on my LAN it freezes and wont play any further. It even does this when playing back on the same computer it is stored. They all work fine how ever when i play them with the Movies and Tv app on my computer. Any help would be appreciated. ffmpeg-remux-29892dec-db1a-4fe5-95ed-ccc767d194f5_1.txt
Abobader 3485 Posted March 12, 2021 Posted March 12, 2021 Hello Bueschere, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Bueschere 0 Posted March 12, 2021 Author Posted March 12, 2021 Here is the server log as well. embyserver.txt
Bueschere 0 Posted March 12, 2021 Author Posted March 12, 2021 (edited) Also it seems to happen anytime I exceed the contents native bitrate by a certain amount because I can very how fast I set my connection to. Some content works at 40mbps others I have to set to 30mbps to get to play. Edited March 12, 2021 by Bueschere
Luke 42203 Posted March 12, 2021 Posted March 12, 2021 Hi, the server has to convert on the fly due to the browser not supporting the audio, and it looks like data is probably just not getting to the browser quickly enough. Do you have any content that the browser supports natively without transcoding that you can compare to? You can also try our Emby Theater desktop app: https://emby.media/emby-theater.html This can direct play more formats without server transcoding, making it more of an equivalent comparison to what you see with the Movies & TV app.
Bueschere 0 Posted March 12, 2021 Author Posted March 12, 2021 Thank you for the reply! I will test this out as soon as I get off work.
Bueschere 0 Posted March 13, 2021 Author Posted March 13, 2021 It didnt work. It wont play any of my m2ts files at all on the emby theater. i cant even stream in 4k at all. its like it just wont work at higher speeds. embyserver (1).txt ffmpeg-transcode-9e369619-f15a-4cae-bd93-b5bafe6e59a3_1.txt ffmpeg-transcode-a1647246-9e7e-47ea-98bb-b7b82c3c2619_1.txt
Bueschere 0 Posted March 13, 2021 Author Posted March 13, 2021 Also all the files I have are either m2ts or mkv pass through files and they both behave the same.
Luke 42203 Posted March 23, 2021 Posted March 23, 2021 On 3/13/2021 at 4:10 AM, Bueschere said: Also all the files I have are either m2ts or mkv pass through files and they both behave the same. Hi, these log examples are from playing in Chrome. What time did you try to play with Theater?
