Davicom 5 Posted March 11, 2021 Posted March 11, 2021 (edited) From windows emby theater, i'm connected to my ubuntu emby server, through openvpn ptp. I need to watch live tv, but direct stream is affected with repeated buffering, probably because on windows i can connect me just through 4g lte. So i tried to reduce, bitrate on client size, but this doesn't affect nothing on server side: I obtain ever just direct stream with no gpu nvidia transcoding. I tried several low resolution, bitrate and internet speed without success. Could you help me in this case? Edited March 11, 2021 by Davicom
CaffNoir 22 Posted March 11, 2021 Posted March 11, 2021 The best way is to use xTeve or use external video player in settings and set with VLC
Davicom 5 Posted March 11, 2021 Author Posted March 11, 2021 thanks for reply, i ll try it. so with vlc the transcode should be start on server side?
Luke 42246 Posted March 11, 2021 Posted March 11, 2021 8 hours ago, Davicom said: From windows emby theater, i'm connected to my ubuntu emby server, through openvpn ptp. I need to watch live tv, but direct stream is affected with repeated buffering, probably because on windows i can connect me just through 4g lte. So i tried to reduce, bitrate on client size, but this doesn't affect nothing on server side: I obtain ever just direct stream with no gpu nvidia transcoding. I tried several low resolution, bitrate and internet speed without success. Could you help me in this case? Hi there, can we please look at an example? Thanks.
Davicom 5 Posted March 11, 2021 Author Posted March 11, 2021 hi luke, better than i explained i can't offer you no one example. sorry. simple no transcoding when it s needed
Luke 42246 Posted March 11, 2021 Posted March 11, 2021 20 minutes ago, Davicom said: hi luke, better than i explained i can't offer you no one example. sorry. simple no transcoding when it s needed Let's look at an example. Please attach the information requested in how to report a problem. Thanks !
