Pre/Post Padding Issue
I've been using MB to record more live TV shows and have taken advantage of the pre/post padding feature.  However, when I increase the post padding minutes and set the show to record MB doesn't save the change.  It records the show with the default post padding minutes of 3.
I can however go back in to the recording I just set via the scheduled page and edit the padding and save.  This time it does actually record with the correct "changed" padding.
MB Version 3.0.5326.13255
ServerWMC Version: 1.0.0.36, build: 1154
Is anyone else seeing this issue as well?
krustyreturns
Traveling right now, but I will check it out when I get home Saturday.
krustyreturns
You are right, this is a bug in serverwmc, I will get it fixed before the next release.
@@krustyreturns while you are at it, is it possible to increase max 30 mins post padding to 2 hours. Overtime games don't normally
finish in half an hour.
Thanks
krustyreturns
Not sure what you mean, is there a post padding max somewhere?  Also you can set serverwmc to automatically use a custom post padding time for sporting events.
