F1nchy 29 Posted March 9, 2021 Posted March 9, 2021 Yes, I agree that Kodi is too fine grained. I would say that 0.25 seconds incremends would be ideal as even that amount can make a noticeable difference, but at least 0.5 seconds increments would be better than the current 1. 2
miniliQuid 95 Posted March 11, 2021 Posted March 11, 2021 I think I like the idea of 0.25, where as 0,5 may be just a tad annoying to get it just right sometimes. Anyway the current is 0.05 I believe? So even 0.1 and 0.2 would be a great improvement for having to tap a lot less
Baenwort 119 Posted May 23, 2021 Posted May 23, 2021 I'd like it to be a user option that each user could set in their settings area with a standard set by the server or just left to the Emby default. 2
raptorjr 15 Posted June 8, 2021 Posted June 8, 2021 I just started using the Android TV app and it only have 1 second intervals. That is too big and not possible to get good. 0.1seconds would be much better. And having to press a few times is much less annoying than having the text offset wrong. Also would like to add a request that the setting is saved. So you don’t have to do it all over again next time you start the video.
miniliQuid 95 Posted June 10, 2021 Posted June 10, 2021 On 6/8/2021 at 7:29 PM, raptorjr said: I just started using the Android TV app and it only have 1 second intervals. That is too big and not possible to get good. 0.1seconds would be much better. And having to press a few times is much less annoying than having the text offset wrong. Also would like to add a request that the setting is saved. So you don’t have to do it all over again next time you start the video. Think that last bit has already been requested. Weird that the android TV app has such huge increments, while most apps have extremely small increments (think it's currently on 0.05 for most apps which is too small of an increment)
ebr 16339 Posted June 10, 2021 Posted June 10, 2021 Hi. This will be addressed in the next release of the app. 1 1
raptorjr 15 Posted June 10, 2021 Posted June 10, 2021 Thank you, that sounds good. Also another thing if it is possible to fix. To remember what language was used the last time searching for a subtitle. Maybe some like it, but I think there is a small number of people that always search for Afar language, or what is first in the list. Probably English would be a better default choice. And even better, remember the last used.
F1nchy 29 Posted June 25, 2021 Author Posted June 25, 2021 I noticed last night that this has now been implemented and I was able to adjust in increments of .25 seconds, which in use is the perfect level of adjustment needed. Many thanks for doing that, very much appreciated!
ebr 16339 Posted June 25, 2021 Posted June 25, 2021 Just FYI for readers, this is in the current beta of the app and will be in the next release. 1
