quickmic 1709 Posted May 5, 2021 Author Posted May 5, 2021 6 hours ago, spon said: (or make it as an option). An option will not impact the current sync implementation.
Red5ive 30 Posted May 5, 2021 Posted May 5, 2021 Is emby-next-gen compatible with the embuary skin on Matrix? I know you have to make an .xml edit to make the skin show up in Matrix but after that does emby next gen 'emulate' or replace emby4kodi and leave all parts of the skin functional?
Sysyphus_ 2 Posted May 6, 2021 Posted May 6, 2021 On 5/4/2021 at 7:12 AM, quickmic said: Please try the beta version and report if it fixes the issue. Hello, I've tried the beta version. It correct the bug, I'm now connected every time. But I not seen my connected avatar in the upper right corner with embuary and on parameter page user and server address are not show. But I think it's due to beta version. Many thanks for the help and your very good job. 1
quickmic 1709 Posted May 7, 2021 Author Posted May 7, 2021 On 5/3/2021 at 7:26 PM, Nosepull said: Yeah, for my internet radio streams I indeed solved the issue by giving the streams the fake artist "Radio". For my usecase this is a viable workaround. However, IMHO it is not good that the plugin fails more or less silently in such cases. Wouldn't it be possible to give those missing artists an obviously false fake artist like "NOARTIST" or something like that, sticking out in Kodi. Then it's up to the user to fix the metadata. Was it synced in 4.x without Artist info? I tried some approaches, but it not easy to inject fake data.
Guest Posted May 8, 2021 Posted May 8, 2021 I fact I had given up on the old plugin long ago, because of all kinds of sync weirdness. So I have no comparision.
Guest Posted May 9, 2021 Posted May 9, 2021 One request: Could you kind of standardize the version numbering? As I see it, there is a beta repo and a stable repo. The stable repo is outdated, but the beta repo seems to be outdated, too, because you can manually download version 5.2.07. And I just noticed that even for 5.2.07 there seem to be different build versions... Why not just keep the beta repo updated? Thanks for your work!
quickmic 1709 Posted May 9, 2021 Author Posted May 9, 2021 (edited) I release experimental versions as pre-review. Usually there it's a work in progress version. e.g. 5.2.07 (experimental): Core change is node re-implementation and it still needs work. Favorites nodes still needs an update. As soon as finished, I push it in beta repo. The current beta 5.2.06 has Kodi 18 issues, that's why I haven't pushed it already in stable repo. Stable repo releases are fully tested with different Kodi version (18 and 19), Different devices (libreelec, osmc, PC, Android) in both modes. Native and plugin and lot's more. Edited May 9, 2021 by quickmic
knewknow 5 Posted May 9, 2021 Posted May 9, 2021 I finally took the plunge and upgraded my two Android boxes to Matrix and next-gen (using Add-on mode for the first time also... always used Native in the past). All seems good so far... just have a few questions. 1. When something new is added to the library (eg. Movie), the old version of the addon used to refresh the kodi library on the fly. Now I need to back out of the movie library and go back in to see the newly added movie. Is this by design? Is there a way to turn this auto-refresh on? 2. Widgets also don't update unless I restart Kodi or Reload the skin. Eg. "Recently added movies". By design? Thanks!!
quickmic 1709 Posted May 9, 2021 Author Posted May 9, 2021 No, not by design. Not sure which version you are using. There are lot's of improvements since 5.1.7 (stable version). You can try beta or experimental.
knewknow 5 Posted May 9, 2021 Posted May 9, 2021 (edited) 8 minutes ago, quickmic said: No, not by design. Not sure which version you are using. There are lot's of improvements since 5.1.7 (stable version). You can try beta or experimental. Interesting. I'm curious if it's the skin that I'm using. I'll do a bit more testing. edit: I'm using the latest beta version. Edited May 9, 2021 by knewknow 1
knewknow 5 Posted May 9, 2021 Posted May 9, 2021 4 hours ago, knewknow said: Interesting. I'm curious if it's the skin that I'm using. I'll do a bit more testing. edit: I'm using the latest beta version. Just tested this @quickmicwith a new copy of Matrix and Emby-NG on a Windows laptop for testing. Using default skin. This time I used native mode so that it was different than my Android installs. - added new movie - checked emby server to ensure it was added - waited on the movie library screen (wall) for about 15 minutes. Library screen was not updated with newly added movie. - exited to home menu on kodi and immediately back into movie library, and it showed up in the list. - checked the newly added movie widget on the home screen. Newly added movie did not show up - checked emby server and the movie was showing under latest movies - restarted kodi, and the movie was showing in the widget Thanks!
quickmic 1709 Posted May 10, 2021 Author Posted May 10, 2021 8 hours ago, knewknow said: Just tested this @quickmicwith a new copy of Matrix and Emby-NG on a Windows laptop for testing. Using default skin. This time I used native mode so that it was different than my Android installs. - added new movie - checked emby server to ensure it was added - waited on the movie library screen (wall) for about 15 minutes. Library screen was not updated with newly added movie. - exited to home menu on kodi and immediately back into movie library, and it showed up in the list. - checked the newly added movie widget on the home screen. Newly added movie did not show up - checked emby server and the movie was showing under latest movies - restarted kodi, and the movie was showing in the widget Thanks! Please check if the websocket connection is online. -> send a (text) message from emby-server to Kodi.
knewknow 5 Posted May 10, 2021 Posted May 10, 2021 (edited) 18 hours ago, quickmic said: Please check if the websocket connection is online. -> send a (text) message from emby-server to Kodi. Thanks @quickmic. How do I do this? I’ve looked everywhere in the settings and can’t seem to find this option... Edit: disregard, I found the option and the text message was received. Edited May 10, 2021 by knewknow
quickmic 1709 Posted May 11, 2021 Author Posted May 11, 2021 5 hours ago, knewknow said: Thanks @quickmic. How do I do this? I’ve looked everywhere in the settings and can’t seem to find this option... Edit: disregard, I found the option and the text message was received. Very good, so the realtime communication between server and Kodi is online. Please send me a kodi.log (via PM), I'll check for errors.
Guest Posted May 12, 2021 Posted May 12, 2021 Is it possible that emby-next-gen conflicts somehow with the internal picture viewer of Kodi? I noticed that I cannot watch my photo library any longer for some time (roughly about the time I started using emby-next-gen). System is Ubuntu 20.10 (now 21.04) with Kodi 19.0 and 19.1 and the 5.2.07 version of the plugin. Pictures are added "conventionally" as a normal path media source in Kodi. When trying to watch a picture everything is fine until I want to see the picture fullscreen. Then the picture is displayed very dark, almost indscernibly. (The "info" overlay, however, has the normal brightness.) Dia shows are not even started. Though the pictures are not accessed via the Emby server and the plugin, the log shows that the plugin somehow takes over: 2021-05-12 18:19:08.893 T:30844 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/fileserver/Photos/2000/00 Misc/pic.jpg', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 1}, 'MonitorMethod': 'Player.OnPlay'} This happens with all pictures. I rule out that something is wrong with all my JPEGs. Displaying the pictures e.g. with the "picture slideshow screensaver" works perfectly. I also tried viewing the pictures directly via the plugin from the Emby server. This does not work also, the screen simply stays black and the log says: 2021-05-12 18:22:14.676 T:31174 INFO <general>: initializing python engine. 2021-05-12 18:22:14.753 T:31181 INFO <general>: Skipped 1 duplicate messages.. 2021-05-12 18:22:14.753 T:31181 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': 'http://127.0.0.1:57578/150480/Images/Primary', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-12 18:22:15.411 T:31176 INFO <general>: CPythonInvoker(80, /home/kodi/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-12 18:22:15.428 T:31176 INFO <general>: Python interpreter stopped 2021-05-12 18:22:15.439 T:31174 INFO <general>: CPythonInvoker(79, /home/kodi/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-12 18:22:15.455 T:31174 INFO <general>: Python interpreter stopped I switched to another Skin, and I disabled the Embuary helper plugin, as this seems to somehow be called when a picture is shown. Any ideas?
quickmic 1709 Posted May 12, 2021 Author Posted May 12, 2021 I'm using the emby picture functions, so I've to perform a test. Basically, there shouldn't be any conflict. Also I'm not using embuary helper addon. I'll check that too.
quickmic 1709 Posted May 13, 2021 Author Posted May 13, 2021 I tested picture functionally. With default skin everything is working fine: 2021-05-13 12:13:45.938 T:22509 INFO <general>: INFO: EMBY.library.Library: --<[ retrieve changes ] 2021-05-13 12:13:46.794 T:22455 ERROR <general>: Unable to lookup host: 'folder.jpg' 2021-05-13 12:13:46.801 T:22455 ERROR <general>: CCurlFile::Exists - Failed: Couldn't resolve host name(6) for http://folder.jpg/ 2021-05-13 12:13:49.015 T:22464 INFO <general>: CPythonInvoker(1, /home/quickmic/.kodi/addons/service.xbmc.versioncheck/resources/lib/runner.py): script successfully run 2021-05-13 12:13:49.093 T:22464 INFO <general>: Python interpreter stopped 2021-05-13 12:13:49.951 T:22437 INFO <general>: Loading skin file: MyPics.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:38.106 T:22437 INFO <general>: Loading skin file: SlideShow.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:38.128 T:22614 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 002.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 1}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:39.427 T:22616 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 003.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:40.126 T:22617 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 004.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:40.725 T:22618 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 003.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:43.504 T:22600 ERROR <general>: Unable to lookup host: 'folder.jpg' 2021-05-13 12:14:43.511 T:22600 ERROR <general>: CCurlFile::Exists - Failed: Couldn't resolve host name(6) for http://folder.jpg/ 2021-05-13 12:14:46.476 T:22437 INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:47.640 T:22437 INFO <general>: Stopping player 2021-05-13 12:14:47.640 T:22437 INFO <general>: Storing total System Uptime 2021-05-13 12:14:47.640 T:22437 INFO <general>: Saving settings 2021-05-13 12:14:47.647 T:22437 INFO <general>: Saving skin settings 2021-05-13 12:14:47.648 T:22437 INFO <general>: Stopping all 2021-05-13 12:14:47.648 T:22437 INFO <general>: ES: Stopping event server 2021-05-13 12:14:47.929 T:22478 INFO <general>: ES: UDP Event server stopped 2021-05-13 12:14:48.257 T:22437 INFO <general>: stopping upnp 2021-05-13 12:14:48.527 T:22463 WARNING <general>: WARNING: EMBY.entrypoint.Service: ---<[ EXITING ] embuary helper addon not tested yet.
quickmic 1709 Posted May 13, 2021 Author Posted May 13, 2021 13 minutes ago, quickmic said: I tested picture functionally. With default skin everything is working fine: 2021-05-13 12:13:45.938 T:22509 INFO <general>: INFO: EMBY.library.Library: --<[ retrieve changes ] 2021-05-13 12:13:46.794 T:22455 ERROR <general>: Unable to lookup host: 'folder.jpg' 2021-05-13 12:13:46.801 T:22455 ERROR <general>: CCurlFile::Exists - Failed: Couldn't resolve host name(6) for http://folder.jpg/ 2021-05-13 12:13:49.015 T:22464 INFO <general>: CPythonInvoker(1, /home/quickmic/.kodi/addons/service.xbmc.versioncheck/resources/lib/runner.py): script successfully run 2021-05-13 12:13:49.093 T:22464 INFO <general>: Python interpreter stopped 2021-05-13 12:13:49.951 T:22437 INFO <general>: Loading skin file: MyPics.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:38.106 T:22437 INFO <general>: Loading skin file: SlideShow.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:38.128 T:22614 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 002.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 1}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:39.427 T:22616 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 003.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:40.126 T:22617 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 004.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:40.725 T:22618 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/1977 Dezember/1977 Dezember - 003.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:14:43.504 T:22600 ERROR <general>: Unable to lookup host: 'folder.jpg' 2021-05-13 12:14:43.511 T:22600 ERROR <general>: CCurlFile::Exists - Failed: Couldn't resolve host name(6) for http://folder.jpg/ 2021-05-13 12:14:46.476 T:22437 INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:14:47.640 T:22437 INFO <general>: Stopping player 2021-05-13 12:14:47.640 T:22437 INFO <general>: Storing total System Uptime 2021-05-13 12:14:47.640 T:22437 INFO <general>: Saving settings 2021-05-13 12:14:47.647 T:22437 INFO <general>: Saving skin settings 2021-05-13 12:14:47.648 T:22437 INFO <general>: Stopping all 2021-05-13 12:14:47.648 T:22437 INFO <general>: ES: Stopping event server 2021-05-13 12:14:47.929 T:22478 INFO <general>: ES: UDP Event server stopped 2021-05-13 12:14:48.257 T:22437 INFO <general>: stopping upnp 2021-05-13 12:14:48.527 T:22463 WARNING <general>: WARNING: EMBY.entrypoint.Service: ---<[ EXITING ] embuary helper addon not tested yet. Another test with Titan Skin (including embuary helper addon). Also no issues found. 2021-05-13 12:29:22.443 T:24138 INFO <general>: CPythonInvoker(26, /home/quickmic/.kodi/addons/script.embuary.helper/default.py): script successfully run 2021-05-13 12:29:22.633 T:23004 INFO <general>: Loading skin file: SlideShow.xml, load type: KEEP_IN_MEMORY 2021-05-13 12:29:22.642 T:24138 INFO <general>: Python interpreter stopped 2021-05-13 12:29:22.652 T:24155 INFO <general>: initializing python engine. 2021-05-13 12:29:22.682 T:24189 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/2019 F1 (Singapore)/DSC_0023.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 1}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:29:22.871 T:24139 INFO <general>: CPythonInvoker(27, /home/quickmic/.kodi/addons/script.embuary.helper/default.py): script successfully run 2021-05-13 12:29:23.076 T:24139 INFO <general>: Python interpreter stopped 2021-05-13 12:29:23.477 T:24155 INFO <general>: CPythonInvoker(28, /home/quickmic/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-13 12:29:23.655 T:24155 INFO <general>: Python interpreter stopped 2021-05-13 12:29:24.370 T:24201 INFO <general>: initializing python engine. 2021-05-13 12:29:24.445 T:24205 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/2019 F1 (Singapore)/DSC_0024.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:29:24.849 T:24201 INFO <general>: CPythonInvoker(29, /home/quickmic/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-13 12:29:24.948 T:24214 INFO <general>: initializing python engine. 2021-05-13 12:29:25.049 T:24201 INFO <general>: Python interpreter stopped 2021-05-13 12:29:25.050 T:24215 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/2019 F1 (Singapore)/DSC_0025.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:29:25.527 T:24214 INFO <general>: CPythonInvoker(30, /home/quickmic/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-13 12:29:25.706 T:24214 INFO <general>: Python interpreter stopped 2021-05-13 12:29:25.781 T:24227 INFO <general>: initializing python engine. 2021-05-13 12:29:25.808 T:24228 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/2019 F1 (Singapore)/DSC_0026.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:29:26.241 T:24227 INFO <general>: CPythonInvoker(31, /home/quickmic/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-13 12:29:26.410 T:24227 INFO <general>: Python interpreter stopped 2021-05-13 12:29:27.152 T:24240 INFO <general>: initializing python engine. 2021-05-13 12:29:27.213 T:24252 INFO <general>: INFO: EMBY.hooks.player.Player: [ OnPlay ] {'item': {'file': '/mnt/storage0/pictures/2019 F1 (Singapore)/DSC_0027.JPG', 'type': 'picture'}, 'player': {'playerid': 2, 'speed': 0}, 'MonitorMethod': 'Player.OnPlay'} 2021-05-13 12:29:27.629 T:24240 INFO <general>: CPythonInvoker(32, /home/quickmic/.kodi/addons/script.embuary.helper/plugin.py): script successfully run 2021-05-13 12:29:27.789 T:24240 INFO <general>: Python interpreter stopped 2021-05-13 12:29:29.779 T:24278 INFO <general>: initializing python engine. 2021-05-13 12:29:30.890 T:24279 INFO <general>: Skipped 1 duplicate messages.. 2021-05-13 12:29:30.890 T:24279 INFO <general>: CPythonInvoker(34, /home/quickmic/.kodi/addons/script.skinshortcuts/default.py): script successfully run 2021-05-13 12:29:31.072 T:24279 INFO <general>: Python interpreter stopped 2021-05-13 12:29:31.347 T:24278 INFO <general>: CPythonInvoker(33, /home/quickmic/.kodi/addons/script.skin.helper.widgets/plugin.py): script successfully run 2021-05-13 12:29:31.481 T:24278 INFO <general>: Python interpreter stopped 2021-05-13 12:29:31.781 T:23004 INFO <general>: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
Guest Posted May 14, 2021 Posted May 14, 2021 (edited) Thanks once again to @quickmic for the quick feedback. I disabled (though not uninstalled) your plugin and the problem persists, so it might be unrelated. Using the built-in Kodi functions, my photos are displayed too dark. At least this worked until a few weeks ago. Using the dynamic list provided by the Emby plugin gives black screens, with no helpful information provided in the log. I'm quite at a loss how to get the picture viewer functionality working again in one way or another. As I'm pretty much using a standard setup (Ubuntu packages on Intel hardware), I'm a bit perplexed where the problem lies... EDIT: Ok, now I tried around a bit. It seems that the Emby plugin is indeed not the culprit. If I want to see pictures in Kodi, it's always the same: dimmed picture (Kodi native) or black picture (Kodi native slideshow and Emby plugin). Sorry for your time! Edited May 14, 2021 by Nosepull Additional info
Guest Posted May 14, 2021 Posted May 14, 2021 On 5/3/2021 at 7:26 PM, Nosepull said: Yeah, for my internet radio streams I indeed solved the issue by giving the streams the fake artist "Radio". For my usecase this is a viable workaround. However, IMHO it is not good that the plugin fails more or less silently in such cases. Wouldn't it be possible to give those missing artists an obviously false fake artist like "NOARTIST" or something like that, sticking out in Kodi. Then it's up to the user to fix the metadata. This issue seems to have creeped back while I'm following your 5.2.07 pre-releases: Somehow this workaround does not work any longer, the *strm-files with fake "artisit"-field no longer are available via the emby-next-gen plugin.
Guest Posted May 14, 2021 Posted May 14, 2021 I don't know if this is related, but it looks as if my Kodi library folder is filled up with (probably stale?) files from emby-next-gen: drwxr-xr-x 3 kodi users 4096 Mai 2 05:59 'emby_Internet-Radio_(8c9daa1e2db7)' drwxr-xr-x 3 kodi users 4096 Mai 2 07:03 'emby_Internet-Radio_(mediaserver)' drwxr-xr-x 3 kodi users 4096 Mai 1 15:35 'emby_Internet-Radio_(e008e2663ede)' drwxr-xr-x 3 kodi users 4096 Apr 19 17:18 'emby_Internet-Radio_(homeserver)' drwxr-xr-x 3 kodi users 4096 Apr 3 09:53 embymusic8a05b0252259a1dbd62df97522638439 drwxr-xr-x 3 kodi users 4096 Apr 3 09:53 embymusic935caf68c9dfcb2c18cc334265e80a5a drwxr-xr-x 3 kodi users 4096 Mai 9 06:18 emby_music_Internet-Radio drwxr-xr-x 3 kodi users 4096 Mai 9 06:18 emby_music_Music drwxr-xr-x 3 kodi users 4096 Mai 2 05:59 'emby_Music_(8c9daa1e2db7)' drwxr-xr-x 3 kodi users 4096 Mai 2 07:03 'emby_Music_(mediaserver)' drwxr-xr-x 3 kodi users 4096 Mai 1 15:35 'emby_Music_(e008e2663ede)' drwxr-xr-x 3 kodi users 4096 Apr 19 17:18 'emby_Music_(homeserver)' So there are entries defined by the name of my Emby instance (mediaserver), by the hostname where my Emby instance is running (homeserver), and other entry points. I have two libraries with music, one names "Music" (containing MP3s etc.) and one named "Internet-Radio" (containing only strm-files). IMHO there should only be two such folders and not 12?!
quickmic 1709 Posted May 14, 2021 Author Posted May 14, 2021 (old) Nodes are never deleted, due to compatibility reason. I recommend delete all nodes manually and restart Kodi. New nodes will be rebuild and you have a "clean" system.
Guest Posted May 14, 2021 Posted May 14, 2021 Just now, quickmic said: (old) Nodes are never deleted, due to compatibility reason. I recommend delete all nodes manually and restart Kodi. New nodes will be rebuild and you have a "clean" system. What exactly do I have to delete? The whole library/music folder, or only those drawers starting with "emby"?
quickmic 1709 Posted May 14, 2021 Author Posted May 14, 2021 50 minutes ago, Nosepull said: This issue seems to have creeped back while I'm following your 5.2.07 pre-releases: Somehow this workaround does not work any longer, the *strm-files with fake "artisit"-field no longer are available via the emby-next-gen plugin. I'll check that, but I have an idea what's wrong. Firstly please delete "old" nodes, I've to be sure you are use the correct selection...
quickmic 1709 Posted May 14, 2021 Author Posted May 14, 2021 (edited) 3 minutes ago, Nosepull said: What exactly do I have to delete? The whole library/music folder, or only those drawers starting with "emby"? you can delete the content of the library folder. kodi/userdata/library/* Probably take a backup before. As mention, if a custom skin uses "old" nodes, the skin is broken and you have to reconfigure widgets, shortcuts... everything. Edited May 14, 2021 by quickmic
