quickmic 1709 Posted March 23, 2021 Author Posted March 23, 2021 New Beta version released and synced with emby-kodi beta repo: If there are no major issues reported in the next two week, this will be the next stable version: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/5.2.05
t123thomas 63 Posted March 23, 2021 Posted March 23, 2021 40 minutes ago, quickmic said: New Beta version released and synced with emby-kodi beta repo: If there are no major issues reported in the next two week, this will be the next stable version: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/5.2.05 I am testing on Wins10 and Coreelec, I will report issue as I find them, does this version require DB reset?
quickmic 1709 Posted March 23, 2021 Author Posted March 23, 2021 No, 1 minute ago, t123thomas said: I am testing on Wins10 and Coreelec, I will report issue as I find them, does this version require DB reset? Technically not needed. If you had issues with DB sync in the past, probably a good idea. A already corrupted (out of sync) DB will not be repaired by a version update.
t123thomas 63 Posted March 23, 2021 Posted March 23, 2021 48 minutes ago, quickmic said: New Beta version released and synced with emby-kodi beta repo: If there are no major issues reported in the next two week, this will be the next stable version: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/5.2.05 Coreelec I rebuild it from scrach then load e4K 5.2.05 havinf issue logging on with diff users only admin is accepted 2021-03-23 18:16:28.086 T:3677332352 NOTICE: INFO: EMBY.database.database: Add missing column presentation_key 2021-03-23 18:16:28.108 T:3677332352 WARNING: WARNING: EMBY.helper.xmls.Xmls: advancedsettings.xml set data 2021-03-23 18:16:30.848 T:4091949072 NOTICE: Stopping player 2021-03-23 18:16:30.848 T:4091949072 NOTICE: Storing total System Uptime 2021-03-23 18:16:30.849 T:4091949072 NOTICE: Saving settings 2021-03-23 18:16:30.864 T:4091949072 NOTICE: Saving skin settings 2021-03-23 18:16:30.874 T:4091949072 NOTICE: Stopping all 2021-03-23 18:16:30.874 T:4091949072 NOTICE: ES: Stopping event server 2021-03-23 18:16:30.874 T:3677332352 NOTICE: INFO: EMBY.emby.connect.Connect: --[ server/DEFAULT ] 2021-03-23 18:16:30.875 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: Begin connect 2021-03-23 18:16:31.132 T:4091949072 NOTICE: stopping zeroconf publishing 2021-03-23 18:16:31.151 T:4091949072 NOTICE: CWebServer[8080]: Stopped 2021-03-23 18:16:31.502 T:3881603968 NOTICE: ES: UDP Event server stopped 2021-03-23 18:16:31.502 T:4091949072 NOTICE: stop dvd detect media 2021-03-23 18:16:31.883 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: Found Servers: [{u'Name': u'U-ROCK-PC', u'Id': u'3ee5bb58a99b4336876aa53525d507ac', u'Address': u'http://192.168.1.104:8096'}] 2021-03-23 18:16:31.885 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: Begin connectToServers, with 1 servers 2021-03-23 18:16:31.885 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: testing connection mode 2 with server U-ROCK-PC 2021-03-23 18:16:31.886 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: tryConnect url: http://192.168.1.104:8096/emby/system/info/public 2021-03-23 18:16:31.944 T:3677332352 NOTICE: INFO: EMBY.core.connection_manager: calling onSuccessfulConnection with connection mode 2 with server U-ROCK-PC 2021-03-23 18:16:31.978 T:3677332352 NOTICE: INFO: EMBY.helper.utils.Utils: DeviceId loaded: 9939414b-cf02-43aa-aa74-33506e3d33c7 2021-03-23 18:16:31.990 T:3677332352 ERROR: ERROR: EMBY.hooks.monitor.Monitor: EmbyServer Connect error 2021-03-23 18:16:32.016 T:3677332352 WARNING: CPythonInvoker(1, /storage/.kodi/addons/plugin.video.emby-next-gen/service.py): the python script "/storage/.kodi/addons/plugin.video.emby-next-gen/service.py" has left several classes in memory that we couldn't clean up. The classes include: N14PythonBindings30XBMCAddon_xbmc_Player_DirectorE,N9XBMCAddon9xbmcaddon5AddonE,N9XBMCAddon7xbmcgui6DialogE,N9XBMCAddon7xbmcgui6WindowE,N14PythonBindings31XBMCAddon_xbmc_Monitor_DirectorE 2021-03-23 18:16:32.208 T:4091949072 NOTICE: Application stopped 2021-03-23 18:16:32.409 T:4091949072 NOTICE: XBApplicationEx: destroying... 2021-03-23 18:16:35.106 T:4091949072 NOTICE: unload skin 2021-03-23 18:16:35.149 T:4091949072 WARNING: Cleanup: Having to cleanup texture button-fo.png 2021-03-23 18:16:35.150 T:4091949072 WARNING: Cleanup: Having to cleanup texture button-nofo.png 2021-03-23 18:16:35.150 T:4091949072 WARNING: Cleanup: Having to cleanup texture bg.jpg 2021-03-23 18:16:35.153 T:4091949072 WARNING: Cleanup: Having to cleanup texture dialog-bg.png 2021-03-23 18:16:35.155 T:4091949072 WARNING: Cleanup: Having to cleanup texture separator-grey.png 2021-03-23 18:16:35.155 T:4091949072 WARNING: Cleanup: Having to cleanup texture logo.png 2021-03-23 18:16:35.191 T:4091949072 NOTICE: unload sections 2021-03-23 18:16:35.625 T:4091949072 NOTICE: XBApplicationEx: application stopped!
quickmic 1709 Posted March 23, 2021 Author Posted March 23, 2021 (edited) Yes, sorry forgot to mention that. Yes, that's on my todo list. Admin rights are required at the moment. Edited March 23, 2021 by quickmic
t123thomas 63 Posted March 23, 2021 Posted March 23, 2021 2 hours ago, quickmic said: Yes, sorry forgot to mention that. Yes, that's on my todo list. Admin rights are required at the moment. To be ceratin the use must be nust have admin right for this to work
t123thomas 63 Posted March 23, 2021 Posted March 23, 2021 Coreelec log.txt Coreelec test result, something is not write I login with Admin, the system went throught the usual process of syn, thereafter, I restarted the kodi, but it did nor prompt with user name, although the play back is fine, but navigating through movie list is somehow not smoth.
quickmic 1709 Posted March 24, 2021 Author Posted March 24, 2021 (edited) There is a "EmbyServer Connect error" even the connection logs looking good. Please try disable very connection. Maybe it helps. I'm already working on a solution... Edited March 24, 2021 by quickmic
reas11 2 Posted March 24, 2021 Posted March 24, 2021 Is there anyway to stop the add-on reloading the skin when it signs in? I believe the previous emby for Kodi add-on didn't have this effect. Not a major issue but causes some skins to load twice when first opening Kodi, meaning a 5-7 second delay before Kodi is usable.
quickmic 1709 Posted March 26, 2021 Author Posted March 26, 2021 On 3/25/2021 at 12:05 AM, reas11 said: Is there anyway to stop the add-on reloading the skin when it signs in? I believe the previous emby for Kodi add-on didn't have this effect. Not a major issue but causes some skins to load twice when first opening Kodi, meaning a 5-7 second delay before Kodi is usable. Correct, at the moment this is on purpose. I try to change it, but not find a better way to refresh the artwork without reloading the complete skin.
spon 26 Posted March 30, 2021 Posted March 30, 2021 Hi guys. Quick question. I used Kodi years ago but have been using Emby exclusively for 5+ years now. Recently re-installed Kodi and emby-next-gen pretty much solely to be able to show MetaCritic and Rotten Tomatoes scores. As I understand it, emby server does not have a place to store Metacritic scores, even though they are pulled with the OMDB scraper. my question - does anyone know if using Emby as the server and Kodi as the front end via emby-next-gen will allow for the scraping and display of MetaCritic scores? Thanks!
heula 192 Posted April 1, 2021 Posted April 1, 2021 I have some issues with tv show recordings that do not show up in Kodi. See this topic. In Kodi I can select all kind of options for my libraries but there is no option to select "active recordings" in the Recordings library. Is it possible to get that option in Kodi so I can use that as a widget? Thanks.
quickmic 1709 Posted April 1, 2021 Author Posted April 1, 2021 (edited) 3 hours ago, heula said: I have some issues with tv show recordings that do not show up in Kodi. See this topic. In Kodi I can select all kind of options for my libraries but there is no option to select "active recordings" in the Recordings library. Is it possible to get that option in Kodi so I can use that as a widget? Thanks. I reviewed the thread. Not sure how I actually should answer. There are many topics included in this thread. progress updates, sync on kodi startup, sync while running (relatime), recordings, dynamic lists etc. Probably I start with the easy ones Which kodi next gen version are you using. Have you tried the latest experimental (not the beta) version? There are many performance improvements compared with the stable version. Edited April 1, 2021 by quickmic
heula 192 Posted April 1, 2021 Posted April 1, 2021 47 minutes ago, quickmic said: I reviewed the thread. Not sure how I actually should answer. There are many topics included in this thread. progress updates, sync on kodi startup, sync while running (relatime), recordings, dynamic lists etc. Probably I start with the easy ones Which kodi next gen version are you using. Have you tried the latest experimental (not the beta) version? There are many performance improvements compared with the stable version. I was on 5.2.05 beta and I have now updated to the experimental 5.2.06. I will test with this version how things go with tv recordings showing up or not. I will try to explain better what I experience with it. Thanks. 1
heula 192 Posted April 1, 2021 Posted April 1, 2021 (edited) I did a simple test that failed. While Kodi was open I activated 2 recordings in Emby of which only 1 eventually became visible in the recently added episodes widget of Kodi. Also in the Emby recordings library in Kodi, only 1 was visible. A restart of Kodi and after the update process was completed the second recording was still not visible. This requires a manual update. Both recordings are visible in Emby. This happens continuously and it makes no difference whether Kodi is already open or has to be opened when I start the recording or a timer recording is started. I hope that I have been able to indicate it a little more clearly. In addition, I think it takes a very long time before the recordings become visible when you start Kodi. It will then take a while before the Emby Next gen addon is loaded and the welcome screen appears at the top of the screen. Then it takes a while before the update process starts and ends again. All this will take at least 2 minutes and then let's hope that all new recordings have become visible. Maybe the update process of the TV recordings can be separated from the other updates and given priority? I'm all trying to think along with this. And what are the possibilities with "Active recordings" in Kodi? Thanks. Recordings In Kodi Recordings in Emby. Red lined is not visible in Kodi. kodi.log kodi.old.log embyserver.txt Edited April 1, 2021 by heula
quickmic 1709 Posted April 1, 2021 Author Posted April 1, 2021 Thanks for the logs. I'll review it. btw, I'll drop my findings in the other thread (testing experimental versions...). 1
Guest Posted April 3, 2021 Posted April 3, 2021 (edited) Thanks for your work with this plugins. A few questions: Is it expected behaviour that a library is no longer available as "dynamic" in the plugin as soon as it is integrated in the Kodi library? Why? I notice that both the TuneIn-plugin and internet radio stations integrated with "*.strm"-files are not accessible with the plugin. Folder structure is shown, but not the contents. Bug or intended behaviour? (Podcast plugin i.e. works fine.) My music library contain several drawers which I like to navigate to also separately. That seems to be possible as the plugin provides separate library nodes per drawer. But as soon as you enter this library node, you end up with the classic listing of artist/genre/album/etc. which again contains all music titles, not only those in the selected drawer. Is it possible that "add users to session" does no longer work with the latest beta (works with non-beta version)? I noticed that the plugin seems to have added two new media sources, empty "http://" and "smb://". Ony for videos, not for music. What are those good for? Are there any users of the Netflix plugin in Kodi? How have you set up Kodi, Emby and the plugin? Edited April 3, 2021 by Nosepull
quickmic 1709 Posted April 3, 2021 Author Posted April 3, 2021 44 minutes ago, Nosepull said: Thanks for your work with this plugins. A few questions: Is it expected behaviour that a library is no longer available as "dynamic" in the plugin as soon as it is integrated in the Kodi library? Why? I notice that both the TuneIn-plugin and internet radio stations integrated with "*.strm"-files are not accessible with the plugin. Folder structure is shown, but not the contents. Bug or intended behaviour? (Podcast plugin i.e. works fine.) My music library contain several drawers which I like to navigate to also separately. That seems to be possible as the plugin provides separate library nodes per drawer. But as soon as you enter this library node, you end up with the classic listing of artist/genre/album/etc. which again contains all music titles, not only those in the selected drawer. Is it possible that "add users to session" does no longer work with the latest beta (works with non-beta version)? I noticed that the plugin seems to have added two new media sources, empty "http://" and "smb://". Ony for videos, not for music. What are those good for? Are there any users of the Netflix plugin in Kodi? How have you set up Kodi, Emby and the plugin? Please test with bleeding edge version (experimental) from here: Several reported issues are already fixed. The stable version has just the very basic functionalities. Let me know, what issues are not covered and I'll put it on my list.
spon 26 Posted April 4, 2021 Posted April 4, 2021 Hi guys. Just bumping a previous question. Is it possible to use Emby Server with emby-next-gen and Kodi in order to scrape and display Metacritic ratings? Thanks
Guest Posted April 5, 2021 Posted April 5, 2021 On 4/3/2021 at 7:08 PM, quickmic said: Please test with bleeding edge version (experimental) from here: Several reported issues are already fixed. The stable version has just the very basic functionalities. Let me know, what issues are not covered and I'll put it on my list. Thanks for the quick reply. The new beta version fixed an issue I wasn't even aware of: As I have bad experiences with the original addon messing up my Kodi database I only tried your new addon for the music library. I didn't even notice that about half of my songs were simply missing (without any hint that there had been a problem with the sync). The new addon version seems to have fixed that - a bit, now all albums are doubled, repairing database does not help... I have to admit that makes me a bit sceptical, because of stuff like that I had given up on the original plugin, I hope that will get better with your new version. Concerning my question, however, only the part with "add users to session" seems to have changed with the new version. Music library is only accessible as a whole, despite the fact that the plugin seems to offer separate library nodes for different drawers TuneIn plugin shows only drawers, listing of stations empty/error STRM-files are not handled for both music and videos (maybe related to the TuneIn problem, as in both cases the media is not physically present on the server)? Librarys are no longer accessible dynamically as soon as they have been added to the library Empty smb:// and http:// video media source created
ojessie 4 Posted April 8, 2021 Posted April 8, 2021 Hi there, first of all thanks for developing a new plugin for kodi. Highly appreciate. I just installed the latest beta 5.2.0.5 and having the same problem as previously mentioned. The music library syncs only a fraction to kodi. What ever I do, restart, rescan, etc. etc. nothing helps. I didn't test any other libraries / functions. Any help is appreciated. Thanks.
quickmic 1709 Posted April 9, 2021 Author Posted April 9, 2021 On 4/5/2021 at 9:24 AM, Nosepull said: Thanks for the quick reply. The new beta version fixed an issue I wasn't even aware of: As I have bad experiences with the original addon messing up my Kodi database I only tried your new addon for the music library. I didn't even notice that about half of my songs were simply missing (without any hint that there had been a problem with the sync). The new addon version seems to have fixed that - a bit, now all albums are doubled, repairing database does not help... I have to admit that makes me a bit sceptical, because of stuff like that I had given up on the original plugin, I hope that will get better with your new version. Concerning my question, however, only the part with "add users to session" seems to have changed with the new version. Music library is only accessible as a whole, despite the fact that the plugin seems to offer separate library nodes for different drawers TuneIn plugin shows only drawers, listing of stations empty/error STRM-files are not handled for both music and videos (maybe related to the TuneIn problem, as in both cases the media is not physically present on the server)? Librarys are no longer accessible dynamically as soon as they have been added to the library Empty smb:// and http:// video media source created Quote Music library is only accessible as a whole, despite the fact that the plugin seems to offer separate library nodes for different drawers Will check, should not be the case. Quote STRM-files are not handled for both music and videos (maybe related to the TuneIn problem, as in both cases the media is not physically present on the server)? Please send me a content sample of the strm files. Quote Librarys are no longer accessible dynamically as soon as they have been added to the library Yes, that's the way it should be. Libs are still accessable but not via dynamic nodes. Quote Empty smb:// and http:// video media source created In the kodi sources file? I think this part of the code was just migrated from 4.x to 5.x. Not sure if this is still needed.
quickmic 1709 Posted April 9, 2021 Author Posted April 9, 2021 16 hours ago, ojessie said: Hi there, first of all thanks for developing a new plugin for kodi. Highly appreciate. I just installed the latest beta 5.2.0.5 and having the same problem as previously mentioned. The music library syncs only a fraction to kodi. What ever I do, restart, rescan, etc. etc. nothing helps. I didn't test any other libraries / functions. Any help is appreciated. Thanks. I'll update the beta on weekend. Please try again and report if this will solve the issue.
Guest Posted April 9, 2021 Posted April 9, 2021 2 hours ago, quickmic said: Quote Music library is only accessible as a whole, despite the fact that the plugin seems to offer separate library nodes for different drawers Will check, should not be the case. It might be that this is Emby related. I just noticed that the Jellyfin plugin for Mopidy shows the same behaviour: My music library consists of several paths, so yes, you can browse the library by those different paths. In the next step you can select the artist. In this step you only see the artists contained in this specific path. But as soon as you select an artist, and the artist is contained in both paths, e.g. "Various artists", in the next step you can see artists from the whole library, not only from the path you started the navigation. This is about the same behaviour I noticed in the emby-next-gen plugin. The *.strm-files I like to play look like this: https://stream.rockantenne.de/rockantenne/stream/mp3
Guest Posted April 10, 2021 Posted April 10, 2021 Short question: Does it currently (Emby Matrix) still happen that a cleanup of the Kodi library removes the Emby entries?
