quickmic 1709 Posted August 12, 2021 Author Posted August 12, 2021 (edited) sideload from here: https://kodi.emby.tv/Public testing/plugin.video.emby-next-gen-6.0.3-build 151 (ex23).zip or in Kodi (install from zip) -> filebrowser -> kodi.emby.media -> public testing -> latest version Edited August 12, 2021 by quickmic
wakeboarder141 40 Posted August 12, 2021 Posted August 12, 2021 5 hours ago, quickmic said: sideload from here: https://kodi.emby.tv/Public testing/plugin.video.emby-next-gen-6.0.3-build 151 (ex23).zip or in Kodi (install from zip) -> filebrowser -> kodi.emby.media -> public testing -> latest version The experimental version doesn't seem to have fixed any of my problems. I am still missing episodes of shows that cover multiple folders. I am also still having problem with Dolby Vision playback. The video and/or audio flickers in and out.
quickmic 1709 Posted August 13, 2021 Author Posted August 13, 2021 10 hours ago, wakeboarder141 said: The experimental version doesn't seem to have fixed any of my problems. I am still missing episodes of shows that cover multiple folders. Can you please send me a kodi.log of the sync process. Quote I am also still having problem with Dolby Vision playback. The video and/or audio flickers in and out. hmm, not sure if this issue is related to next-gen plugin. I try to find a Dolby vision content file for a test.
jonomite 29 Posted August 23, 2021 Posted August 23, 2021 Hello @quickmic! Recently upgraded from 5.3.4 to the latest experimental version. I did a full database reset. All seems to be working well. The only minor issue I'm currently experiencing is that, after a period of time streaming content, my Emby dashboard no longer reports that the content is being streamed (although it is). I can see the media there initially, but the dashboard just stops reporting it at some point, as best I can tell. Oddly, this doesn't seem to affect the server saving my resume position.
quickmic 1709 Posted August 23, 2021 Author Posted August 23, 2021 1 hour ago, jonomite said: Hello @quickmic! Recently upgraded from 5.3.4 to the latest experimental version. I did a full database reset. All seems to be working well. The only minor issue I'm currently experiencing is that, after a period of time streaming content, my Emby dashboard no longer reports that the content is being streamed (although it is). I can see the media there initially, but the dashboard just stops reporting it at some point, as best I can tell. Oddly, this doesn't seem to affect the server saving my resume position. Please send me a log when this happens. Are you using native or addon mode?
jonomite 29 Posted August 23, 2021 Posted August 23, 2021 Sure, I'll try to get you a log later today. I'm using native mode - I like having chapter thumbnails and using the Extras add-on for special features, and it's my understanding that neither of those would work in addon mode.
quickmic 1709 Posted August 24, 2021 Author Posted August 24, 2021 (edited) 15 hours ago, jonomite said: Sure, I'll try to get you a log later today. I'm using native mode - I like having chapter thumbnails and using the Extras add-on for special features, and it's my understanding that neither of those would work in addon mode. I investigated how the extras add-on works. Unfortunately, it needs native pathes, yes (no workaround possible ). Probably I can adopt the extras functions in next-gen addon context menu. Edited August 24, 2021 by quickmic
quickmic 1709 Posted August 24, 2021 Author Posted August 24, 2021 (edited) On 8/23/2021 at 3:47 PM, jonomite said: Sure, I'll try to get you a log later today. I'm using native mode - I like having chapter thumbnails and using the Extras add-on for special features, and it's my understanding that neither of those would work in addon mode. Extras (added directly to next-gen plugin) will be added in next experimental version, chapter thumbnails not possible Edited August 24, 2021 by quickmic
jonomite 29 Posted August 25, 2021 Posted August 25, 2021 Hmm. The method to post a log seems to have changed since the last time I submitted one. How does one access it now?
Nerto 4 Posted September 7, 2021 Posted September 7, 2021 Hi,in the newest beta version (6.0.5-build 122 (ex9)) strm files doesn't work anymore. You always get the Error "File doesn't exist anymore". The problem is that in the table files the strFileName only shows ?url=example and not plugin://plugin.video.example/?url=example so kodi doesn't find the data anymore. If i replace the lines Filename = obj['FullPath'].rsplit('\\', 1)[1] if '\\' in obj['FullPath'] else obj['FullPath'].rsplit('/', 1)[1] Filename = self.EmbyServer.Utils.StringDecode(Filename) to Filename = obj['FullPath' . It works again. Greetings Nerto 1
quickmic 1709 Posted September 7, 2021 Author Posted September 7, 2021 7 minutes ago, Nerto said: Hi,in the newest beta version (6.0.5-build 122 (ex9)) strm files doesn't work anymore. You always get the Error "File doesn't exist anymore". The problem is that in the table files the strFileName only shows ?url=example and not plugin://plugin.video.example/?url=example so kodi doesn't find the data anymore. If i replace the lines Filename = obj['FullPath'].rsplit('\\', 1)[1] if '\\' in obj['FullPath'] else obj['FullPath'].rsplit('/', 1)[1] Filename = self.EmbyServer.Utils.StringDecode(Filename) to Filename = obj['FullPath' . It works again. Greetings Nerto Thanks, will check it.
quickmic 1709 Posted September 7, 2021 Author Posted September 7, 2021 4 hours ago, Nerto said: Hi,in the newest beta version (6.0.5-build 122 (ex9)) strm files doesn't work anymore. You always get the Error "File doesn't exist anymore". The problem is that in the table files the strFileName only shows ?url=example and not plugin://plugin.video.example/?url=example so kodi doesn't find the data anymore. If i replace the lines Filename = obj['FullPath'].rsplit('\\', 1)[1] if '\\' in obj['FullPath'] else obj['FullPath'].rsplit('/', 1)[1] Filename = self.EmbyServer.Utils.StringDecode(Filename) to Filename = obj['FullPath' . It works again. Greetings Nerto Can you please perform a test with this code: same file as you modified common.py, same function: get_filename rollback your modifications (even if this works for you, it breaks native content) and try this: replace: if Temp.startswith("plugin://"): ForceNativeMode = True elif Temp.endswith(".bdmv"): ForceNativeMode = True with: if Temp.startswith("plugin://"): return obj['FullPath'] elif Temp.endswith(".bdmv"): ForceNativeMode = True I have no testcase for plugin content. Thanks
Nerto 4 Posted September 7, 2021 Posted September 7, 2021 9 minutes ago, quickmic said: Can you please perform a test with this code: same file as you modified common.py, same function: get_filename rollback your modifications (even if this works for you, it breaks native content) and try this: replace: if Temp.startswith("plugin://"): ForceNativeMode = True elif Temp.endswith(".bdmv"): ForceNativeMode = True with: if Temp.startswith("plugin://"): return obj['FullPath'] elif Temp.endswith(".bdmv"): ForceNativeMode = True I have no testcase for plugin content. Thanks I'm still at work right now. I will test it later. Sorry my change was only meant as a tip not as a fix. 1
quickmic 1709 Posted September 7, 2021 Author Posted September 7, 2021 Just now, Nerto said: I'm still at work right now. I will test it later. Sorry my change was only meant as a tip not as a fix. Yes, and much appreciated! I like bug reports with possible solutions included Meanwhile I uploaded a new experimental version with the modification. I hope it fixes the plugin issue.
Nerto 4 Posted September 10, 2021 Posted September 10, 2021 On 9/7/2021 at 4:09 PM, quickmic said: Yes, and much appreciated! I like bug reports with possible solutions included Meanwhile I uploaded a new experimental version with the modification. I hope it fixes the plugin issue. With the new Version plugin.video.emby-next-gen-6.0.6-build 45 (ex6).zip strms are working again. Many Thanks 1
Guest Posted September 19, 2021 Posted September 19, 2021 Hi, this might be a stupid question but I couldn't find a way to do it. How can I change a user after selecting it for the first time according to the current viewer? Thanks
Kocane 14 Posted September 19, 2021 Posted September 19, 2021 I was just watching a movie which played fine for well over an hour but when I paused for a few minutes and returned to playback, it played for a few seconds and then froze. When I tried to 'stop' the video, Kodi seemed to freeze entirely. This is what I got from the log. Is there anything to gather from this? Running Kodi 19 with 5.3.4
quickmic 1709 Posted September 20, 2021 Author Posted September 20, 2021 6 hours ago, Kocane said: I was just watching a movie which played fine for well over an hour but when I paused for a few minutes and returned to playback, it played for a few seconds and then froze. When I tried to 'stop' the video, Kodi seemed to freeze entirely. This is what I got from the log. Is there anything to gather from this? Running Kodi 19 with 5.3.4 Could be a Kodi problem, this this a one time only issue for all videos?
Kocane 14 Posted September 22, 2021 Posted September 22, 2021 On 9/20/2021 at 7:03 AM, quickmic said: Could be a Kodi problem, this this a one time only issue for all videos? It probably is. I'll see if it happens again. Thanks 1
Junias 9 Posted September 25, 2021 Posted September 25, 2021 Hi there, I have a little problem. Every time I play a file with latest 5.3.3 Version on Kodi (series or movie) with Addon, after playing is complete Kodi crashes. Do you have any suggestions / is this a known bug or do you need a log? Thanks!
quickmic 1709 Posted September 25, 2021 Author Posted September 25, 2021 12 minutes ago, Junias said: Hi there, I have a little problem. Every time I play a file with latest 5.3.3 Version on Kodi (series or movie) with Addon, after playing is complete Kodi crashes. Do you have any suggestions / is this a known bug or do you need a log? Thanks! You can try latest experimental version: https://kodi.emby.tv/Public testing/plugin.video.emby-next-gen-6.0.10-build 47 (ex5).zip It requires a full database rsync! And yes, please send me a kodi log.
quickmic 1709 Posted October 1, 2021 Author Posted October 1, 2021 New beta version available: BETA VERSION 6.0.12: https://github.com/MediaBrowser/plugin.video.emby/releases/tag/6.0.12 Download link for manual update: https://github.com/MediaBrowser/plugin.video.emby/archive/refs/tags/6.0.12.zip (also available via Emby-Kodi beta repository). This version requires a full database resync!
RaptorCentauri 59 Posted October 1, 2021 Posted October 1, 2021 The multi select for native mode seems to not be working anymore. Was this feature removed?
quickmic 1709 Posted October 1, 2021 Author Posted October 1, 2021 54 minutes ago, RaptorCentauri said: The multi select for native mode seems to not be working anymore. Was this feature removed? Looks like a bug, I'll check it.
quickmic 1709 Posted October 1, 2021 Author Posted October 1, 2021 (edited) 1 hour ago, RaptorCentauri said: The multi select for native mode seems to not be working anymore. Was this feature removed? Works fine here, please double check and send me a kodi.log Maybe I find something. I think I found the problem. Will be fixed in next beta Edited October 1, 2021 by quickmic
