dmacleo 1 Posted March 5, 2021 Posted March 5, 2021 emby 4.5.4.0 on server 2016 essentials version 1607 build 14393.4225 hardware acceleration turned off. seeing this in log titled hardware_detection_xxx not sure its causing any issues just caught my eye. {"ApplicationVersion":"4.5.4.0","VersionType":"Release","ReleaseCode":"1fe08461aa31429baaf05a48105bb6c9","OperatingSystem":"Windows","OperatingSystemName":"Win32NT","OperatingSystemVersion":"Microsoft Windows 10.0.14393","OsArchitecture":"x64","ProcessArchitecture":"x64","VideoDecoders":{},"VideoEncoders":{"1: libx264 Software Encoder":{"SupportedPresets":["superfast","veryfast","faster","fast","medium","slow","slower","veryslow"],"MinConstantRateFactor":0,"MaxConstantRateFactor":51,"FrameworkCodec":"libx264","IsHardwareCodec":false,"SupportsParameters":true,"CompatibleDecoderFrameworks":[],"VideoMediaType":"h264","ProfilesWithLevel":[{"Profile":"AvcProfileBaseline","Level":"AvcLevel62"},{"Profile":"AvcProfileMain","Level":"AvcLevel62"},{"Profile":"AvcProfileHigh","Level":"AvcLevel62"},{"Profile":"AvcProfileHigh10","Level":"AvcLevel62"},{"Profile":"AvcProfileHigh422","Level":"AvcLevel62"},{"Profile":"AvcProfileHigh444","Level":"AvcLevel62"}],"SupportedProfiles":["AvcProfileBaseline","AvcProfileMain","AvcProfileHigh","AvcProfileHigh10","AvcProfileHigh422","AvcProfileHigh444"],"SupportedLevels":["AvcLevel1b","AvcLevel1","AvcLevel11","AvcLevel12","AvcLevel13","AvcLevel2","AvcLevel21","AvcLevel22","AvcLevel3","AvcLevel31","AvcLevel32","AvcLevel4","AvcLevel41","AvcLevel42","AvcLevel5","AvcLevel51","AvcLevel52","AvcLevel6","AvcLevel61","AvcLevel62"],"Direction":"Encoder","SupportedColorFormats":[],"CommandGenerator":{},"CodecDeviceInfo":{"Capabilities":{"SupportsHwUpload":false,"SupportsHwDownload":false,"SupportsStandaloneDeviceInit":false,"Supports10BitProcessing":false},"Adapter":0,"Name":"Software Codec","Desription":"Software Codec","DeviceId":0,"VendorId":0},"CodecKind":"Video","MediaTypeName":"H.264 (AVC)","SupportedColorFormatStrings":[],"ProfileAndLevelInformation":[{"Profile":{"ShortName":"AvcProfileBaseline","Description":"Baseline Profile","Details":"Primarily for low-cost applications that require additional data loss robustness, this profile is used in some videoconferencing and mobile applications. This profile includes all features that are supported in the Constrained Baseline Profile, plus three additional features that can be used for loss robustness (or for other purposes such as low-delay multi-point video stream compositing). The importance of this profile has faded somewhat since the definition of the Constrained Baseline Profile in 2009. All Constrained Baseline Profile bitstreams are also considered to be Baseline Profile bitstreams, as these two profiles share the same profile identifier code value.","Id":"AvcProfiles.AvcProfileBaseline"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}},{"Profile":{"ShortName":"AvcProfileMain","Description":"Main Profile","Details":"This profile is used for standard-definition digital TV broadcasts that use the MPEG-4 format as defined in the DVB standard. It is not, however, used for high-definition television broadcasts, as the importance of this profile faded when the High Profile was developed in 2004 for that application.","Id":"AvcProfiles.AvcProfileMain"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}},{"Profile":{"ShortName":"AvcProfileHigh","Description":"High Profile","Details":"The primary profile for broadcast and disc storage applications, particularly for high-definition television applications (for example, this is the profile adopted by the Blu-ray Disc storage format and the DVB HDTV broadcast service).","Id":"AvcProfiles.AvcProfileHigh"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}},{"Profile":{"ShortName":"AvcProfileHigh10","Description":"High 10 Profile","Details":"Going beyond typical mainstream consumer product capabilities, this profile builds on top of the High Profile, adding support for up to 10 bits per sample of decoded picture precision.","Id":"AvcProfiles.AvcProfileHigh10"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}},{"Profile":{"ShortName":"AvcProfileHigh422","Description":"High 4:2:2 Profile","Details":"Primarily targeting professional applications that use interlaced video, this profile builds on top of the High 10 Profile, adding support for the 4:2:2 chroma subsampling format while using up to 10 bits per sample of decoded picture precision.","Id":"AvcProfiles.AvcProfileHigh422"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}},{"Profile":{"ShortName":"AvcProfileHigh444","Description":"High 4:4:4 Predictive Profile","Details":"This profile builds on top of the High 4:2:2 Profile, supporting up to 4:4:4 chroma sampling, up to 14 bits per sample, and additionally supporting efficient lossless region coding and the coding of each picture as three separate color planes.","Id":"AvcProfiles.AvcProfileHigh444"},"Level":{"ShortName":"AvcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"781 Mbit/s","MaxBitRateDisplay":"781 Mbit/s","Id":"AvcLevels.AvcLevel62","ResolutionRates":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRateStrings":["8192x4320@120","7680x4320@129","3840x2160@300"],"ResolutionRatesDisplay":"8192x4320@120, 7680x4320@129, 3840x2160@300"}}],"Id":"V-E-libx264","Name":"libx264 Software Encoder","SecondaryFramework":"None","IsEnabledByDefault":false,"DefaultPriority":0},"2: libx265 Software Encoder":{"SupportedPresets":["ultrafast","superfast","veryfast","faster","fast","medium","slow","slower","veryslow","placebo"],"MinConstantRateFactor":0,"MaxConstantRateFactor":51,"FrameworkCodec":"libx265","IsHardwareCodec":false,"SupportsParameters":true,"CompatibleDecoderFrameworks":[],"VideoMediaType":"hevc","ProfilesWithLevel":[{"Profile":"HevcProfileMain","Level":"HevcLevel62"},{"Profile":"HevcProfileMain10","Level":"HevcLevel62"}],"SupportedProfiles":["HevcProfileMain","HevcProfileMain10"],"SupportedLevels":["HevcLevel1","HevcLevel2","HevcLevel21","HevcLevel3","HevcLevel31","HevcLevel4","HevcLevel41","HevcLevel5","HevcLevel51","HevcLevel52","HevcLevel6","HevcLevel61","HevcLevel62"],"Direction":"Encoder","SupportedColorFormats":[],"CommandGenerator":{},"CodecDeviceInfo":{"Capabilities":{"SupportsHwUpload":false,"SupportsHwDownload":false,"SupportsStandaloneDeviceInit":false,"Supports10BitProcessing":false},"Adapter":0,"Name":"Software Codec","Desription":"Software Codec","DeviceId":0,"VendorId":0},"CodecKind":"Video","MediaTypeName":"H.265 (HEVC)","SupportedColorFormatStrings":[],"ProfileAndLevelInformation":[{"Profile":{"ShortName":"HevcProfileMain","Description":"Main Profile","Details":"The Main profile allows for a bit depth of 8-bits per sample with 4:2:0 chroma sampling, which is the most common type of video used with consumer devices.","Id":"HevcProfiles.HevcProfileMain"},"Level":{"ShortName":"HevcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"234 Mbit/s","MaxBitRateDisplay":"234 Mbit/s","Id":"HevcLevels.HevcLevel62","ResolutionRates":["3840x2160@300","7680x4320@128","8192x4320@120","8192x8192@60"],"ResolutionRateStrings":["3840x2160@300","7680x4320@128","8192x4320@120","8192x8192@60"],"ResolutionRatesDisplay":"3840x2160@300, 7680x4320@128, 8192x4320@120, 8192x8192@60"}},{"Profile":{"ShortName":"HevcProfileMain10","Description":"Main 10 Profile","Details":"The Main 10 profile allows for a bit depth of 8-bits to 10-bits per sample with 4:2:0 chroma sampling. allows for improved video quality since it can support video with a higher bit depth than what is supported by the Main profile.[140] Additionally, in the Main 10 profile 8-bit video can be coded with a higher bit depth of 10-bits, which allows improved coding efficiency compared to the Main profile.","Id":"HevcProfiles.HevcProfileMain10"},"Level":{"ShortName":"HevcLevel62","Description":"Level 6.2","Ordinal":62,"MaxBitRate":"234 Mbit/s","MaxBitRateDisplay":"234 Mbit/s","Id":"HevcLevels.HevcLevel62","ResolutionRates":["3840x2160@300","7680x4320@128","8192x4320@120","8192x8192@60"],"ResolutionRateStrings":["3840x2160@300","7680x4320@128","8192x4320@120","8192x8192@60"],"ResolutionRatesDisplay":"3840x2160@300, 7680x4320@128, 8192x4320@120, 8192x8192@60"}}],"Id":"V-E-libx265","Name":"libx265 Software Encoder","SecondaryFramework":"None","IsEnabledByDefault":false,"DefaultPriority":0},"3: MPEG-4 part 2 Software Encoder":{"FrameworkCodec":"mpeg4","IsHardwareCodec":false,"SupportsParameters":false,"CompatibleDecoderFrameworks":[],"VideoMediaType":"mpeg4","ProfilesWithLevel":[],"SupportedProfiles":[],"SupportedLevels":[],"Direction":"Encoder","SupportedColorFormats":[],"CommandGenerator":{},"CodecDeviceInfo":{"Capabilities":{"SupportsHwUpload":false,"SupportsHwDownload":false,"SupportsStandaloneDeviceInit":false,"Supports10BitProcessing":false},"Adapter":0,"Name":"Software Codec","Desription":"Software Codec","DeviceId":0,"VendorId":0},"CodecKind":"Video","MediaTypeName":"MPEG-4","SupportedColorFormatStrings":[],"ProfileAndLevelInformation":[],"Id":"V-E-mpeg4","Name":"MPEG-4 part 2 Software Encoder","SecondaryFramework":"None","IsEnabledByDefault":false,"DefaultPriority":0},"4: MPEG-4 part 2 (MS Variant 3) Software Encoder":{"VideoMediaType":"msmpeg4v3","FrameworkCodec":"msmpeg4","SupportsParameters":false,"IsHardwareCodec":false,"CompatibleDecoderFrameworks":[],"ProfilesWithLevel":[],"SupportedProfiles":[],"SupportedLevels":[],"Direction":"Encoder","SupportedColorFormats":[],"CommandGenerator":{},"CodecDeviceInfo":{"Capabilities":{"SupportsHwUpload":false,"SupportsHwDownload":false,"SupportsStandaloneDeviceInit":false,"Supports10BitProcessing":false},"Adapter":0,"Name":"Software Codec","Desription":"Software Codec","DeviceId":0,"VendorId":0},"CodecKind":"Video","MediaTypeName":"MPEG-4 part 2 Microsoft variant version 3","SupportedColorFormatStrings":[],"ProfileAndLevelInformation":[],"Id":"V-E-msmpeg4","Name":"MPEG-4 part 2 (MS Variant 3) Software Encoder","SecondaryFramework":"None","IsEnabledByDefault":false,"DefaultPriority":0},"5: libvpx VP8":{"MinConstantRateFactor":4,"MaxConstantRateFactor":63,"FrameworkCodec":"libvpx","IsHardwareCodec":false,"SupportsParameters":false,"CompatibleDecoderFrameworks":[],"VideoMediaType":"vp8","ProfilesWithLevel":[{"Profile":"Vp8Profile0","Level":"Vp8levelDefault"}],"SupportedProfiles":["Vp8Profile0"],"SupportedLevels":["Vp8levelDefault"],"Direction":"Encoder","SupportedColorFormats":[],"CommandGenerator":{},"CodecDeviceInfo":{"Capabilities":{"SupportsHwUpload":false,"SupportsHwDownload":false,"SupportsStandaloneDeviceInit":false,"Supports10BitProcessing":false},"Adapter":0,"Name":"Software Codec","Desription":"Software Codec","DeviceId":0,"VendorId":0},"CodecKind":"Video","MediaTypeName":"VP8","SupportedColorFormatStrings":[],"ProfileAndLevelInformation":[{"Profile":{"ShortName":"Vp8Profile0","Description":"Profile 0","Details":"For non-zero values the encoder increasingly optimizes for reduced complexity playback on low powered devices at the expense of encode quality. For example using 1 tells the encoder only to use only bi-linear sub pixel filtering and a simplified loop filter. In general most users will want to set a value of 0 or ignore this parameter unless they are encoding high resolution content and require playback on very low power devices.","Id":"Vp8Profiles.Vp8Profile0"},"Level":{"ShortName":"Vp8levelDefault","Description":"Default Level","Ordinal":0,"Id":"Vp8Levels.Vp8levelDefault","ResolutionRates":[],"ResolutionRateStrings":[],"ResolutionRatesDisplay":""}}],"Id":"V-E-libvpx","Name":"libvpx VP8","SecondaryFramework":"None","IsEnabledByDefault":false,"DefaultPriority":0}},"EncodingOptions":{"EncodingThreadCount":0,"ExtractionThreadCount":1,"TranscodingTempPath":"F:\\ProgramData\\Emby\\transcodetemp","DownMixAudioBoost":2,"EnableThrottling":false,"ThrottleBufferSize":120,"ThrottleHysteresis":8,"H264Crf":20,"H264Preset":"slow","EnableHardwareEncoding":true,"EnableSubtitleExtraction":true,"CodecConfigurations":[],"HardwareAccelerationMode":0},"DetectionOutputs":{"Dx11VaCodecProvider":{"CodecProviderName":"Dx11VaCodecProvider","Result":[ "Detection Log", "Debug: Create DXGI Factory", "Debug: DXGI Factory created", "Debug: Detected 2 video adapters.", "Debug: Dispose DXGI Factory", "Debug: DXGI Factory disposed" ] },"QuickSyncCodecProvider":{"CodecProviderName":"QuickSyncCodecProvider","StandardError":"ffdetect version 4.3.0-emby_2020_05_23-g8f222573e9+530 Copyright (c) 2018-2019 softworkz for Emby LLC\r\n built with gcc 9.2.0 (Rev2, Built by MSYS2 project)\r\n configuration: --enable-amf --enable-bzlib --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --disable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-cuda-nvcc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++\r\n libavutil 56. 36.100 / 56. 36.100\r\nAdapter number 0 outside of range. 0 adapters available.\r\nAdapter number 1 outside of range. 0 adapters available.\r\nAdapter number 2 outside of range. 0 adapters available.\r\nAdapter number 3 outside of range. 0 adapters available.\r\n\r\n","Result":{ "ProgramVersion": { "Version": "4.3.0-emby_2020_05_23-g8f222573e9+530", "Copyright": "Copyright (c) 2018-2019 softworkz for Emby Llc", "Compiler": "gcc 9.2.0 (Rev2, Built by MSYS2 project)", "Configuration": " --enable-amf --enable-bzlib --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --disable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-cuda-nvcc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++" }, "Devices": [ { "DeviceIndex": 0, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 1, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 2, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 3, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } } ], "Log": [ { "Level": 16, "Category": 0, "Message": "Adapter number 0 outside of range. 0 adapters available." }, { "Level": 16, "Category": 0, "Message": "Adapter number 1 outside of range. 0 adapters available." }, { "Level": 16, "Category": 0, "Message": "Adapter number 2 outside of range. 0 adapters available." }, { "Level": 16, "Category": 0, "Message": "Adapter number 3 outside of range. 0 adapters available." } ] } ,"ExitCode":0},"QuickSyncDx11CodecProvider":{"CodecProviderName":"QuickSyncDx11CodecProvider","StandardError":"ffdetect version 4.3.0-emby_2020_05_23-g8f222573e9+530 Copyright (c) 2018-2019 softworkz for Emby LLC\r\n built with gcc 9.2.0 (Rev2, Built by MSYS2 project)\r\n configuration: --enable-amf --enable-bzlib --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --disable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-cuda-nvcc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++\r\n libavutil 56. 36.100 / 56. 36.100\r\nFailed creating the D3D11 device: -2005270524.\r\nFailed creating the D3D11 device: -2005270524.\r\nIDXGIFactory2_EnumAdapters failed: -2005270526.\r\nIDXGIFactory2_EnumAdapters failed: -2005270526.\r\n\r\n","Result":{ "ProgramVersion": { "Version": "4.3.0-emby_2020_05_23-g8f222573e9+530", "Copyright": "Copyright (c) 2018-2019 softworkz for Emby Llc", "Compiler": "gcc 9.2.0 (Rev2, Built by MSYS2 project)", "Configuration": " --enable-amf --enable-bzlib --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --disable-sdl2 --disable-debug --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-cuda-nvcc --enable-gmp --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwavpack --enable-libwebp --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libaom --enable-version3 --enable-libzvbi --enable-gnutls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++" }, "Devices": [ { "DeviceIndex": 0, "DeviceInfo": { "Description": "Microsoft Basic Render Driver", "DirectXType": "DX11_1", "DeviceId": 140, "VendorId": 5140, "SubSysId": 0, "AdapterLuidHigh": 0, "AdapterLuidLow": 45460, "DedicatedSystemMemory": 0, "DedicatedVideoMemory": 0, "SharedSystemMemory": 19320578048 }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 1, "DeviceInfo": { "Description": "Microsoft Basic Render Driver", "DirectXType": "DX11_1", "DeviceId": 140, "VendorId": 5140, "SubSysId": 0, "AdapterLuidHigh": 0, "AdapterLuidLow": 45629, "DedicatedSystemMemory": 0, "DedicatedVideoMemory": 0, "SharedSystemMemory": 19320578048 }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 2, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } }, { "DeviceIndex": 3, "DeviceInfo": { }, "Error": { "Number": -3, "Message": "Error initializing an MFX session: MFX_ERR_UNSUPPORTED" } } ], "Log": [ { "Level": 16, "Category": 0, "Message": "Failed creating the D3D11 device: -2005270524." }, { "Level": 16, "Category": 0, "Message": "Failed creating the D3D11 device: -2005270524." }, { "Level": 16, "Category": 0, "Message": "IDXGIFactory2_EnumAdapters failed: -2005270526." }, { "Level": 16, "Category": 0, "Message": "IDXGIFactory2_EnumAdapters failed: -2005270526." } ]
Happy2Play 9802 Posted March 5, 2021 Posted March 5, 2021 I guess this could be a good question why Emby still queries your hardware even if you don't use HWA. But to my knowledge Emby always queries hardware via Hardware Detect.
dmacleo 1 Posted March 5, 2021 Author Posted March 5, 2021 really I don't see any issues except an extra log entry thats (in my case) irrelevant. just caught my eye.
Luke 42203 Posted March 6, 2021 Posted March 6, 2021 There aren't any errors. That's just part of the detection process.
