Tau512 15 Posted June 9, 2022 Author Posted June 9, 2022 i gave up and bought the quadro p400 2GB card for nvenc. perfect results. i've also upgraded from the athlon to i5 8600k for home server which i'll be testing with the intel igpu at the weekend maybe. I'm not sure if i put it down to it being linux amd drivers, or the 'vce' features on the athlon 3000G igpu just not being upto scratch. i never really got to the bottom of why the AMD system was so poor.
Timmy1980 0 Posted June 9, 2022 Posted June 9, 2022 Thanks for the reply. I am using a Ryzen 3 2200g with Vega 8 GPU, wasn't planning on changing the GPU but might do as the rest of the setup is fine for what I want it to do... which is basically Emby for media library and Live TV/DVR.
Carlo 4561 Posted June 10, 2022 Posted June 10, 2022 (edited) On 6/9/2022 at 10:49 AM, Timmy1980 said: Thanks for the reply. I am using a Ryzen 3 2200g with Vega 8 GPU, wasn't planning on changing the GPU but might do as the rest of the setup is fine for what I want it to do... which is basically Emby for media library and Live TV/DVR. What CPU do you have? Does it support QuickSync? Never mind, as pointed out how blind I was typing that you don't have QuickSync available with the Ryzen. Edited June 10, 2022 by cayars
GrimReaper 4926 Posted June 10, 2022 Posted June 10, 2022 5 minutes ago, cayars said: What CPU do you have? Does it support QuickSync? Carlo? On 6/9/2022 at 11:49 AM, Timmy1980 said: I am using a Ryzen 3 2200g 1
ulanov 16 Posted June 11, 2022 Posted June 11, 2022 (edited) I think this is part of the same issue I flagged here. If you scroll down two comments below that post you'll see that I think I have isolated where the problem came into the Android mobile APK version. However, this thread suggests it may be not an Android issue but something to do with a shared codec or other factor. What is in common is that it affects 480 SD play in some code builds. I hope this might help @Luke chase it down. As far as I can tell it affects all Android mobile devices running the recent APKs (3.2.40 forward including the current 3.2.50), but it didn't affect APKs 3.2.32 and earlier. And as noted this is a problem with 480 SD in particular. (At least it held true on five separate devices I tested half a dozen APK versions on, with different native DPIs and native aspect ratios and the results were uniform.) Perhaps importantly the server is running on a QNAP (has been consistent across QNAP server versions past and present), so it could conceivably be tied to QNAP hardware/software just as earlier in this thread thinking it might be server device dependent. I have NOT tested this on an Emby server running on any other non-QNAP hardware. Edited June 11, 2022 by ulanov 1
Luke 42288 Posted June 16, 2022 Posted June 16, 2022 On 6/10/2022 at 9:28 PM, ulanov said: I think this is part of the same issue I flagged here. If you scroll down two comments below that post you'll see that I think I have isolated where the problem came into the Android mobile APK version. However, this thread suggests it may be not an Android issue but something to do with a shared codec or other factor. What is in common is that it affects 480 SD play in some code builds. I hope this might help @Luke chase it down. As far as I can tell it affects all Android mobile devices running the recent APKs (3.2.40 forward including the current 3.2.50), but it didn't affect APKs 3.2.32 and earlier. And as noted this is a problem with 480 SD in particular. (At least it held true on five separate devices I tested half a dozen APK versions on, with different native DPIs and native aspect ratios and the results were uniform.) Perhaps importantly the server is running on a QNAP (has been consistent across QNAP server versions past and present), so it could conceivably be tied to QNAP hardware/software just as earlier in this thread thinking it might be server device dependent. I have NOT tested this on an Emby server running on any other non-QNAP hardware. That's helpful info. Thanks.
