ebr 16334 Posted May 31, 2021 Posted May 31, 2021 Hi. Have you tried re-muxing or re-encoding this item? Also, if you can send a new log with the latest beta we can see if anything is different. Thanks.
thymon 11 Posted June 4, 2021 Author Posted June 4, 2021 (edited) Hello @Luke @ebr Thanks to follow my issue. So I will not try to re-muxing this item. Because this concerns all HEVC 4K (HEVC 1080p works). As soon as possible, I send the error report from the FireTV. Edited June 4, 2021 by thymon
Luke 42240 Posted June 4, 2021 Posted June 4, 2021 2 hours ago, thymon said: Hello @Luke @ebr Thanks to follow my issue. So I will not try to re-muxing this item. Because this concerns all HEVC 4K (HEVC 1080p works). As soon as I can, I send the error report from the FireTV. Great, thanks.
thymon 11 Posted June 7, 2021 Author Posted June 7, 2021 @Luke Hello, Log sended from few minutes from FireTV
ebr 16334 Posted June 7, 2021 Posted June 7, 2021 3 hours ago, thymon said: @Luke Hello, Log sended from few minutes from FireTV Hi. Unfortunately, I did not get any of the playback information in that log. Please try sending it right from the playback screen (under the cog menu). Thanks.
thymon 11 Posted June 7, 2021 Author Posted June 7, 2021 27 minutes ago, ebr said: Hi. Unfortunately, I did not get any of the playback information in that log. Please try sending it right from the playback screen (under the cog menu). Thanks. This is exactly how the logs were sent.
ebr 16334 Posted June 7, 2021 Posted June 7, 2021 2 minutes ago, thymon said: This is exactly how the logs were sent. The log I saw was sent from the user menu on the home screen after playback had already stopped. Can you please try again from the cog menu during playback?
thymon 11 Posted June 7, 2021 Author Posted June 7, 2021 35 minutes ago, ebr said: The log I saw was sent from the user menu on the home screen after playback had already stopped. Can you please try again from the cog menu during playback? Ahhh damn. Ok !!
thymon 11 Posted July 9, 2021 Author Posted July 9, 2021 @ebr Hi I sended log from FireTv HD on 7 Jully at 14h05 (UTC+2). It has an improvement since the last update. Now there are no more error messages, and the sound is working. But the screen is black.
ebr 16334 Posted July 10, 2021 Posted July 10, 2021 16 hours ago, thymon said: Hi I sended log from FireTv HD on 7 Jully at 14h05 (UTC+2). Hi. The 7th or the 9th? What user was logged in and what item did you play? Thanks.
ebr 16334 Posted July 12, 2021 Posted July 12, 2021 Can you please confirm the date and time you sent the log and what you tried to play? Thanks.
thymon 11 Posted July 12, 2021 Author Posted July 12, 2021 Yes 07/07/2021 Harry Potter I think… and others but I do not remember…
ebr 16334 Posted July 15, 2021 Posted July 15, 2021 Okay, I cannot find a log near that date and time. I found one on July 8th at that time but the user was "Jean-Pierre" and there was no playback in the log as it was sent from the home screen instead of from the playback OSD menu.
thymon 11 Posted July 17, 2021 Author Posted July 17, 2021 (edited) ok @ebr It was me on July 8th. I maked a mistake. I will try to sent this from the OSD menu the next time. Edited July 17, 2021 by thymon
Luke 42240 Posted July 18, 2021 Posted July 18, 2021 9 hours ago, thymon said: ok @ebr It was me on July 8th. I maked a mistake. I will try to sent this from the OSD menu the next time. Great, thanks !
thymon 11 Posted July 22, 2021 Author Posted July 22, 2021 Hello new send today at 3h30pm (utc+2). from «Patrick F» user.
ebr 16334 Posted July 25, 2021 Posted July 25, 2021 Hi. Thanks for the new log. The problem is that the device doesn't support HEVC so we are trying to decode it on device with ffmpeg but the hardware just cannot handle it. The latest beta of the app will not try to do this and transcode on the server instead. You can get that here: 1
thymon 11 Posted July 30, 2021 Author Posted July 30, 2021 Hello @ebr HEVC really ? Because if I watch a HEVC 1080p movies. There is not a problem. it is HEVC 4K only
thymon 11 Posted August 10, 2021 Author Posted August 10, 2021 Hello, tested on update 2.0.33a -> same issue. As if amazon was doing it on purpose to buy the 4k version.
ebr 16334 Posted August 10, 2021 Posted August 10, 2021 2 hours ago, thymon said: tested on update 2.0.33a -> same issue. Hi. Can you please send another app log with this version? Thanks.
